Planning My Lawn Sprinkler System - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-11-2010, 09:40 AM   #31
Just call me Andrew
Rewards Points: 1,020
Once I get the pipe run outside, I will be testing the pressure with a gauge on a boiler drain outside as well as the GPM.
Andrew
secutanudu is offline   Reply With Quote
Old 07-11-2010, 10:29 AM   #32
Licensed Master Plumber
I would be testing before running any pipe.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 07-11-2010, 10:32 AM   #33
Just call me Andrew
Wouldn't testing it now be inaccurate, since all I have in my house is 1/2" pipe? I know the pressure is between 70 and 80...but won't the flow rate be way higher on my 1" pipe?
Andrew
Old 07-11-2010, 10:58 AM   #34
No it won't. You could have a 1/4" pipe with 300 lbs pressure and no volume. Increasing the pipe size does not increase volume.
Old 07-12-2010, 01:53 PM   #35
Sorry NHMaster, but you are mistaken, larger pipe sizes will flow higher volumes as a function of the reduced pressure loss. The flow through a 1/2" pipe and a 1" pipe will be significantly different at an 80 psi supply pressure. A 1/2" pipe will flow 5 gpm while a 1" pipe will flow 27 gpm at the same 70 psi residual pressure. Larger pipe sizes = higher volumes of water traveling through the pipe with no restrictions.
The Engineer is offline   Reply With Quote
Old 07-16-2010, 10:26 AM   #36
Just call me Andrew
So I ran my piping outside. Is there a way to calculate the GPM? I know I have ~83PSI on the 1" pipe at the boiler drain outside, and the pipe is 1".
I know this won't give me the GPM 50' further down the pipe...but isn't there a way to figure out the GPM at that spot in the pipe? I guess I could put a 5-gallon bucket under the pipe to try and time it, but it's tough to get a good measurement since the water comes out so hard.
Andrew
Old 07-16-2010, 12:38 PM   #37
Doing it myself
Alan's Avatar
Rewards Points: 2,086
But his incoming pipe size is not changing.
Journeyman Plumber
Old 07-16-2010, 12:40 PM   #38
Just call me Andrew
But I will no longer be reducing to 1/2"...that should give me increased flow from my spigot outside (fed by 1/2") but not more flow than my incoming 3/4" line. Right?
Andrew
Old 07-16-2010, 12:47 PM   #39
Doing it myself
Alan's Avatar
How do you have 83 PSI without a pressure regulator? Max is 80.
Journeyman Plumber
Old 07-16-2010, 06:17 PM   #40
Just call me Andrew
Not gonna lie...I love the pressure in my house. Should I really get a regulator to drop it 3 PSI?
Andrew
Old 07-16-2010, 09:35 PM   #41
I've measured 80psi +/- at my house (1950's) too
Same at the last house (1905)
Old 08-21-2010, 09:51 AM   #42
South Jersey
I know this is an old topic but you need to read up at irrigationtutorials.com
That site is an absolute wealth of knowledge. I've read through it probably 4 or 5 times. I got an irrigation design book from the library and I already knew everything in it because of irrigationtutorials.com It def won't make you a pro but if you're a hardcore DIYer the site is a must read.
Reddhead is offline   Reply With Quote
Old 08-21-2010, 10:44 AM   #43
Just call me Andrew
Thanks, I'll check it out. I did a test, and at the point just after my backflow preventer, I have 83PSI and 26 gallons per minute.
I just need to map out where I want my heads and start digging...
Andrew
Old 08-21-2010, 10:57 AM   #44
South Jersey
I assume the 83psi is static psi? The installer I used to work for was happy to see anything over 60psi. What size meter do you have (if any)? They say you shouldn't pull anymore than 15GPM through a 5/8" meter and to design the zones for 10GPM. I have a 5/8" Badger meter and it is rated for 15GPM continuous and a peak of 20GPM. My water supply from the street is 1" copper and about 40ft long. But I only have 51psi to play with.
If you have a larger meter than me and the pipe to support it you could do quite a bit of watering. You should be able to find the documentation on your meter if it has the name/model stamped on it.
Trying to revive dead lawn... deevahs Landscaping & Lawn Care 2 05-13-2010 01:34 PM
DIY Lawn Sprinkling System - Yes - No? Woodcutter Landscaping & Lawn Care 19 02-03-2009 12:35 AM
Hot Water Heating System in older house GrannyAnnie HVAC 2 08-31-2008 05:50 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
Sprinkler System Nathan Landscaping & Lawn Care 1 02-09-2004 11:12 PM
