Planning For Basement Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-21-2013, 10:21 AM   #1
Rewards Points: 244
Hi,
I'm trying to finish my basement bathroom so I am in the planning state.
I have rough-in waste pipes (i.e. sink, toilet, and bathtub).
My plan is that instead of bathtub, I am considering a shower.
Attached is the picture of the rough-in waste pipe for the bathtub. I put the 2" XPS and 2x4 as reference.
Here are the measurement:
* the distance from concrete wall to the center of the rough in pipe is 9"
* When I install the 2"XPS, 2x4, and drywall, I have less 4" left.
This distance may be OK for bathtub, but it would not work for a shower pan. The shower pan requirements is that the drain pipe is about 8.3" from the wall.
I really don't want to jackhammer the slab to re-route the plumbing.
Any idea is appreciated.
Thanks!
Nick
325_man is offline   Reply With Quote
Old 09-21-2013, 12:17 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by 325_man View Post
...instead of bathtub, I am considering a shower.
I really don't want to jackhammer...
Oh well.
Old 09-21-2013, 12:51 PM   #3
Rewards Points: 244
Do you think building a raised platform out of 2x4 so that the pipe can be routed for additional 5" on top of the slab would not work?
Old 09-21-2013, 12:56 PM   #4
MarginallyQualified
Do you think...
Picture and youtube links
Old 09-21-2013, 01:37 PM   #5
Rewards Points: 244
TarheelTerp,
Yes - that is what I am thinking.
I am looking for input, not sarcasm. If you know the answer, then just say it.
Old 09-21-2013, 01:56 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 792
You really need to consider the jack hammer route.
3 hrs includes round trip to the tool rental and hammering and the pipe can be relocated. Probably cheaper than you could build a floor- and faster.
Plus your drain will actually be plumbed right.
Have you confirmed that there is a p trap below the floor?
Old 09-21-2013, 03:28 PM   #7
Plumber
Anther thing to be concerned about is the pipe size.
Tubs are 1 1/2 " and shower require a 2" drain.
DidIDoThat is offline   Reply With Quote
Old 09-21-2013, 03:33 PM   #8
Rewards Points: 244
The rough-in pipe is 2" pipe.
Old 09-21-2013, 03:36 PM   #9
Plumber
Have you considered building a pan to fit ?
Old 09-21-2013, 04:33 PM   #10
Rewards Points: 244
Not a bad idea. Point me to the site.
Old 09-21-2013, 04:44 PM   #11
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,402
Have a stainless pan made.
That way I can see how it works before I make my own. I fab stainless restaurant equipment and have access to it so I will try it in my new upstairs en suite shower. Beats playing with membranes and stuff and the pan will install like a tub.
Oh, and if you need to move the drain, it's really quite simple. I recently did mine.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is offline   Reply With Quote
Old 09-21-2013, 05:00 PM   #12
Rewards Points: 244
If I go back to the bathtub idea, where would the bathtub drain pipe be (above or below the slab surface)?
Old 09-21-2013, 06:48 PM   #13
Rewards Points: 2,032
You will need to break the concrete around your pipe. It would also help if you post a drawing of all your pipes locations. You also will need a permit from your local building department prior to starting work.
bathroom remodel complications megancn Building & Construction 6 07-24-2012 04:38 PM
Duct Work For Bathroom buildit45 HVAC 2 07-07-2012 09:36 PM
help, new wiring for bathroom remodel DIYAUSTIN Electrical 8 06-19-2012 07:45 PM
Bathroom fan replacement reveals...a mess merlanvp Electrical 0 07-25-2010 08:00 PM
Planning for a bathroom rebuild ajtool Kitchen & Bath Remodeling 0 06-03-2010 09:47 PM
