#1 |
Pitless Adapter Submersible Pump
Can anyone answer-when installing a pitless adapter on a well, is the adapter capped just above the adapter or is the pipe ran to the top of the well cap, and the well cap used as a cover? Thanks |
#2 |
I do know some things
Not a plumber, just googled pitless adapter and found this.
scroll towards the bottom http://images.google.com/imgres?imgu...%3Den%26sa%3DN |
#3 |
And if you would be looking for a better brand of pump you can try out using the Geyser brand. I've used it for years and it definitely works wonders for me.
#4 |
To answer your question the pitless adapter is installed in the side of the well casing below the frost line, the same depth you run your water line. Be sure to attach a "T" made of pipe to the adapter so you don't drop it down the well.
#5 |
You can using the Geyser brand.
#6 |
Water quality'n pump guy
The 1" hole in the top of the pitless is used to screw that Tee handle pipe into to enable you to pull the drop pipe, cable and pump out of the well.
Gary Slusser 23 years in water treatment and well pumps, 13 years on the 'net helping others to help themselves. |
| Display Modes | |
| sump pump issue | mikehende | Plumbing | 15 | 02-15-2008 07:36 AM |
| Foundation drain and sump pump | slatergrl | Plumbing | 3 | 02-10-2008 10:36 AM |
| sump pump continuing running | deck hand | Plumbing | 2 | 01-16-2008 05:35 PM |
| Well pump issue-should I be concerned? | Mikedks | Plumbing | 8 | 10-08-2006 11:42 PM |
| intermatic timer with submersible water pump | bardos | Electrical | 2 | 09-02-2006 02:41 AM |
