Piping Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-21-2011, 05:54 PM   #1
Piping question
I am thinking about replacing my water heater(died) with a tankless water heater and have a quick question about piping size. My house is piped with 3/4 inch PVC piping and the sales men at my local hardware store said the tankless water heaters they sell are 1/2 inch input and output. My question is will there be any problem converting down to 1/2 inch to go into the water heater and then back to 1/2 coming out of it as far as water pressure or anything like that? Any input would be great. Thank you.
jake
jmeyer1715 is offline   Reply With Quote
Old 10-21-2011, 06:03 PM   #2
Experienced
Jackofall1's Avatar
There will be no problem reducing on the in and out, what you really have to consider is the size of the gas line to feed a tankless heater. All that I have seen require a 3/4" NG line, which will probably lead to issues with having enough gas/pressure for both your furnace and the tankless heater.
Mark
Old 10-21-2011, 06:06 PM   #3
AlbacoreShuffle's Avatar
I agree with Jack.
Most residential water heaters are rated at 40,000 to 50,000 BTU's.
You tank less is going to be over 200,000 btu's. Not many home have that kind of excess capacity in the gas system.
AlbacoreShuffle is offline   Reply With Quote
Old 10-21-2011, 06:09 PM   #4
Thanks for the fast post Mark. I asked the salesman about the gas line too. I have 1/2 inch NG pipe and he said the models they sell 'Eccotemp' are 1/2 inch. I was assuming I was good there but please let me know if I am wrong.
Thanks again.
jake
Old 10-21-2011, 06:20 PM   #5
The model the guy was talking about is 'Eccotemp FVI-12-NG'. I have a 2 bed, 1 .5 bath home and he said this should be good. I normally don't do laundry or run the dishwasher together or when I'm taking a shower so that's what he recommended. It looks like its 74000 BTU so I'm hoping my current NG line will work. What do you guys think? It looks like it will be an easy install for me. I only need to modify a few things with the plumbing so my thought is if it doesn't work for me its only an hour or two.
Old 10-21-2011, 06:25 PM   #6
Experienced
Jackofall1's Avatar
By the way hello Jake and welcome the best DIY'r site on the web.
Tankless heaters are rated for gpm at a given temperature rise, that being said I looked up a small eccotemp (3.5 gpm) and it was 75,000 btu's/hr.
The problem with that small a capacity is yes it will run from a 1/2" gas line as long as the line isn't too long, but if someone else in the home turns on the HW tap, the shower goes cold.
At a minimum a house with (4) peeps in it needs at least 7.5 gallons which would be more like 200,000 btu's/hr.
Mark
Tags
1/2 , 3/4 , pipes , tankless
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Crawl Space Ventilation with Wiring and Piping Passing Through scubber Building & Construction 1 02-09-2009 09:59 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
