Pipes Are Outside The Wall How Do I Put Them In A Wall? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-26-2012, 09:36 PM   #1
Pipes are outside the wall how do I put them in a wall?
We bought our first house after the fact, we realized they must have ran plumming to baseboards, but they are outside walls, they end up being in closets. I am wondering if it is an easy job to put them behind walls....was a cheap job, I want it looking better so a cosmetic improvement. I have not asked my husband to fix it....just wondering how much work would go into it before I tell him I want it done. Thanks
Mom2cme is offline   Reply With Quote
Old 04-26-2012, 10:04 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 358
what kind and size of pipes?could be more hassle than its worth
Old 04-26-2012, 10:08 PM   #3
Rewards Points: 582
more information is needed ....pictures would be great.....
Old 04-27-2012, 04:02 PM   #4
Rewards Points: 150
I'm not a specialist at hydronic baseboard heating, but what you describe is pretty common. I would not consider it cheap or substandard.
I assume you aren't expecting to embed the pipe in the outside wall, because that would cause energy loss. Moving the pipe over a few inches so it comes up in the wall between the room and closet probably is not worth the expense.
goosebarry is offline   Reply With Quote
Adding wall with door opening - sloped ceiling and no joist for top plate Jebross Remodeling 11 01-11-2012 10:34 AM
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 02:55 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
