Pipes Moaning - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-27-2009, 05:59 PM   #1
Billydee
Smile
Pipes Moaning
A couple of weeks ago my water pipes started 'moanimg'. It is sporadic and at random. It has only happened in the daytime and at random times. Does anyome have any suggestion as to a fix on this problem???
Billydee is offline   Reply With Quote
Old 12-28-2009, 01:30 AM   #2
Do something
D'Brie's Avatar
Pipes Moaning
Do you have a pressure reducing valve (PRV) in your piping? Check your water pressure; should be between 50- 80 psi. I have been on many calls for moaning pipes, usually high water pressure is the culprit.
D'Brie is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK Remodeling 7 11-04-2009 09:10 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK HVAC 5 11-01-2009 09:15 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 10:03 PM
New Natural Gas pipes being installed frplymstr Plumbing 12 01-05-2009 02:18 PM
