Pipes Installed On NORTH Facing Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-12-2012, 09:30 PM   #1
Pipes Installed on NORTH facing wall
Hi I'm new here and need some advice with another winter fast approaching here in New England (CT). The upstairs bathroom sink doesn't run COLD water when it gets too cold outside because the pipes were installed on North facing wall. The hot runs fine. The bathtub has no problems with cold water just the sink mainly (although the toilet next to the sink also sometimes has problems but not as much as the sink). The contractor's "fix" was to install a heater in the corner of the garage below to keep the pipe from freezing. This is a short-term fix in my mind but I have some questions about the proper fix which will come out of my own pocket. Is there an easy way to move the pipe without too much wall repair? The other side of the sink wall is a finished room. The bathroom is on back side of house in-between two finished rooms. Is there another solution? Thanks for your help!
getitdoneright is offline   Reply With Quote
Old 11-14-2012, 05:49 PM   #2
Rewards Points: 704
Can you draw us a diagram or take some pictures? But, it sounds like the pipes/wall are not properly insulated.
Seattle2k is offline   Reply With Quote
Tags
frozen pipes
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 01:26 PM
Framing basement exterior walls gheffron Building & Construction 7 06-08-2012 02:00 AM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 07:23 PM
To seal/cap a wall with plumbing in it, or not... bkraz Building & Construction 6 12-15-2010 08:31 PM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
