Pipes Banging - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-26-2008, 05:00 PM   #1
Pipes Banging
I live in a small garden home that is about 7 years old. If I flush a toilet OR run a sink, everything sounds fine. However, when I flush a toilet AND run a sink, the pipes make a loud banging sound. If I turn off the faucet, silence! Basically, whenever there are 2 different water sources running at the same time, the banging appears. It does not happen every time, but I would say about 80% of the time. Any opinions would be appreciated...
FlyerFan8810 is offline   Reply With Quote
Old 03-26-2008, 05:06 PM   #2
Building and plumbing
USP45's Avatar
Rewards Points: 150
Could be loose pipes in the wall that need to be straped in. It may be ok, but if they are banging around I would be concerned about them hitting and wearing a hole in the pipe.
USP45 is offline   Reply With Quote
Old 03-27-2008, 08:52 PM   #3
remodeling pro
Definately a pipe(S) in the wall that were not properly secured. It just takes the volume of the two fixtures to get enough water flow for the harmonics to kick in. It is also very difficult to isolate exactly were the problem is since the pipe is an excellent sound conduit. You may have some luck with an inexpensive doctor's stethascope, but don't be surprised if you end up a stud or more off of the problem. I have had luck before with just using the stop valves to restrict the flow to the fixtures. You will be amazed at how much you can shut the valves down before really being able to see any problems in their performance,
troubleseeker is offline   Reply With Quote
Old 03-28-2008, 12:33 PM   #4
Rewards Points: 150
Yes its called water hammer. The proof positive way of quieting it is to put a cushion area for it at the right spot,,,which could be trial and error. See if you can find a small charge tank that you could fit up under the sink cabinet, with a bladder and air valve stem like a tire. That would be the least inconspicious place for having it fixed!! OR put a parallel pipe with a cap on it besides the vertical incoming line, the top stays full of air(hard to explain)
justdon is offline   Reply With Quote
Old 03-28-2008, 07:50 PM   #5
remodeling pro
Water hammer is actually a different scenario than described. It is the result of water freely moving through a pipe and then suddenly being stopped by a valve being quickly closed. As we remember from basic science, the water still has forward momentum, so it slams into the closed valve or the end of the pipe run thus sounding like the pipe has been hit with a hammer. This problem is usually caused by appliances that have quick closing valves, such as dishwashers and washing machines. It is usually solved by installing a tank as described , an air chamber in the supply line (just a vertical extension of the supply pipe, located so that it will trap a cushion of air to absorb the water's momentum , or a commercially available arrester chamber. There are even screw on units that can be installed at the valve/machine hose connection to solve this in washing machine locations.
This problem is caused more by the flow of water creating vibrations in the pipe which is then transferred to the studs at the spot where the pipe is not secured, basically creating a musical instrument in the wall, although not exactly an ear pleasing tune.
Old 03-29-2008, 08:24 PM   #6
Does this happen regardless of the toilet that is being run? I have seen balcocks cause the same thing. If its only the one toilet flushing with that faucet causing it I would try changing it and see if that helps. Its a cheap fix sometimes.
http://www.broomfieldplumber.com
plumber Jim is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
frozen pipes helper Plumbing 3 03-23-2008 12:35 PM
banging in pipes e.lukie Plumbing 4 08-19-2007 09:40 PM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 12:06 PM
Is it normal to see green stuff on the supply pipes KUIPORNG Plumbing 2 06-30-2006 11:21 AM
