Pipe Will NOT Budge HELP!!!!!!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2011, 04:06 PM   #1
Pipe will NOT budge HELP!!!!!!!
I am updating my bathroom and trying to replace the tub spout. We finally got the spout itself off but the way it came off was the pipe broke. Now I cannot get the pipe out of the wall. My home was built in 1950 so the pipe has formed a weld tight bond where it has rusted. I cannot saw the pipe off as it is in the wall. I have tried solvents and heating the pipe with a torch. I even tried applying wax to the heated pipe. It still will NOT BUDGE. When they built the house, they plastered the pipe in the wall as well. I have free the pipe by chiseling out the plaster from around the pipe. Nothing. won't budge!!!!!!!
mrsd is offline   Reply With Quote
Old 03-19-2011, 04:22 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 346
did the pipe break at the 90? How much of the valve is accessible?
Old 03-21-2011, 04:16 PM   #3
It broke off with an inch left sticking out of the wall but we ended up having to cut it off at the elbow and cut a slit into the remainder of the elbow to get it of. Now we just have to get the o-rings to reconnect the hot and cold supply. Thanks for your reply though.
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 01:31 PM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 10:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 02:05 AM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 02:42 AM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 12:55 PM
