Pipe U-Turn - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-09-2013, 04:21 PM   #1
Rewards Points: 1,402
Question
Pipe U-Turn
An ancient connection draining a tub gave way.
The tub drains through a 1.5" horizontal brass pipe into a 2" vertical shaft, where it travels down 3 inches (from pipe center to pipe center, or about 0.5 inches between pipe walls) and leaves in the same direction it came from, but about 40 degrees to the left.
Is there any good way to make a connection like that? If not, is there any bad way to make a connection like that that will still work?
The pipes are close enough together that there doesn't seem to be room to use most fittings.
(The connection I am replacing drains through a 2" lead pipe that is round-ish, but then weaves through pipes, into a trap, and curves back around into the horizontal sloped 4" cast-iron waste line)
Edit: Pics Follow.
The vertical distance between the pipe centers is about 3"
There is not a lot of room to work with.
This is where the drain goes--there are actually two tubs draining here. There is a trap in the drain line we are going into already, so using a trap to make the 140 degree turn and 3" drop would create a double-trap.
Tom738 is offline   Reply With Quote
Old 08-09-2013, 05:51 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 772
Sounds like quite a project. We could help a lot more if you could post a picture.
Sent from my iPhone using DIY Forum. Watch out for spell check
Old 08-09-2013, 05:58 PM   #3
Rewards Points: 6,652
Not ancient, they still use Drum traps for various reasons. Just remove and plumb with a standard trap and drain for the tub.
The Following User Says Thank You to gregzoll For This Useful Post:
Tom738 (08-09-2013)
Old 08-09-2013, 06:32 PM   #4
Added pics. I am trying to avoid quite a project.
Old 08-09-2013, 06:36 PM   #5
Interesting. Thanks for the name--drum trap--I'll see if I can find one that will fit there. The size looks a little off--6" with 1.5" diameter holes near either end of the drum suggests the spacing is too big to work--but maybe I can find a shorter one.
(A standard trap there would create a double-trap with the old lead pipe, and I'm not sure I can get through that mess with new rigid pipe to reconnect to the lead further down the line.)
Old 08-09-2013, 06:47 PM   #6
Rewards Points: 13,950
All that old pipe needed to go years ago. Redo the whole thing.
gregzoll (08-09-2013)
Old 08-09-2013, 09:12 PM   #7
Plumber
Rewards Points: 772
You won't have much luck with a new drum trap- they have been illegal traps for tub use for quite some time.
As for lead pipe- it's outdated/obsolete too.
Like Joe said- your best and maybe only option is to remove the lead pipe and traps- replace with DWV plastic pipe and fittings- lead is hard to patch, it's a lost art. Most plumbers have not been exposed to it.
You're up against a very challenging DIY project. Consider getting some quotes from a few plumbers.
If you want to tackle it- guys here will help- put set aside a few nights/days for this.
That is one nasty looking job to tackle
The Following User Says Thank You to TheEplumber For This Useful Post:
Tom738 (08-09-2013)
Old 08-09-2013, 09:24 PM   #8
EPlumber, that is why there is microbrews, paper & pencils for stuff like this. Or just do like most of us, and grab a carpenter's pencil and just doodle on the sub floor, or the back of a piece of drywall, as you think it out.
Of course if the OP is lucky and can find a guy or gal like my plumber, they will fix this mess, and while you are standing there watching, it amazes you that they can do it without having to draw anything out on paper, or sit there and think about it.
Sewer Back Up/ Pipe Relining Question newbinca Plumbing 9 05-10-2013 12:23 PM
Cutting and gluing PVC pipe to washer steve3847 Plumbing 8 10-03-2012 08:00 AM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 09:23 AM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 01:42 AM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 05:40 PM
