Pipe Threading Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-08-2010, 09:46 AM   #1
Pipe threading problems
Hi, I've used pipe threading machines in the past and didnt have this problem. I am using an elbow grease threader and the threads are getting broken off leaving a mess of a thread. some worse than others. I'm putting in a new gas line and dont have access to that nice threading machine and dont want to take chances with these threads.
thanks in advance,
mike
weldman is offline   Reply With Quote
Old 10-08-2010, 11:32 AM   #2
Rewards Points: 84
Check that your cutters are in the right order. They are numbered, and will do exactly what you described if they are not in the right order.
Old 10-08-2010, 01:11 PM   #3
HVAC / Plumbing
cutting oil helps
kenmac is offline   Reply With Quote
Old 10-08-2010, 03:59 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 566
buy quality pipe too, not the foreign stuff made of recycled VW's
Old 10-09-2010, 05:49 PM   #5
Rewards Points: 150
thanks in advance,
mike
You either have some of the junk pipe or your dies are dull.
braindead is offline   Reply With Quote
Old 10-11-2010, 11:16 PM   #6
Problem fixed. I borrowed a newer rigid threader. beautiful threads
I wish i could just weld some of the joints
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
broken pipe under cement atichargr Plumbing 5 04-23-2009 11:15 AM
Iron Pipe Threading tvwav Plumbing 9 03-16-2009 01:33 AM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
