Old 07-29-2012, 12:07 AM   #1
pipe sleeve installed correctly?
So ever since I moved into my new house..my neighbors and i have had nothing but trouble with storm water.
My basement floods...and my neighbors driveway, paved, started to cave in.
I thought it had something to do with the terracota pipe that carried the storm water. I called the company that redid the sewer line and he admitted he hit some pipe and that he sleeved it. Then tried selling me a sump pump for my water trouble.
Rotor rooter shows up and cams the pipe. We notice that he sleeved an 8" clay pipe with a 4" PVC pipe. There was no firnco fitting or sealing. The camera could not get over the lip. Today, I dug it up to see for myself. Whatdya know..its def a 4" pipe sleeved into an 8" pipe. This cannot be code. Water runs down the clay pipe and some goes into the PVC..but 1/2 goes around. Do I have a case against this contractor? He should have used a 8 " PVC with a firnco or put the clay pipe into a 10" then reduce it to a 6" to go into the next clay piece?
Thoughts?
Here's a YouTube link of some video...I just got done discovering it and it rained a lil
https://www.youtube.com/watch?v=XhRg...e_gdata_player
dja3137 is offline   Reply With Quote
Old 07-29-2012, 12:10 AM   #2
The video is looking at the "sleeve". Up from that PVC is the clay pipe..which is upstream carrying water down.
Old 07-29-2012, 07:50 AM   #3
Thoughts?
keep the video call back the company that did the repair......he will get the point..
Was this flat rubber/EPDM Roof installed correctly mose Roofing 5 03-26-2012 06:27 PM
Working with B-Vent pipe for WH vent BobN HVAC 16 01-26-2012 12:58 AM
Driveway culvert to underground pipe zrooster99 Landscaping & Lawn Care 4 06-25-2011 01:42 PM
Walk-in shower frame installed correctly? drpcken Plumbing 4 03-12-2010 06:07 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
