Old 07-24-2007, 05:29 PM   #1
Question
pipe size for tub, floor, and bath sink drains
should i use 1-1/2 or 2 in PVC pipe for
1. bath tub
2. floor drain
3. bathroom sink
thanks,
- a
Old 07-24-2007, 07:28 PM   #2
Mechanical Contractor
1. bath tub 1 1/2"
2. floor drain 3"
3. bathroom sink 1 1/2"
thanks,
- a
Don't forget you need a trap purger for the floor drain.
100% Union and proud of it.
MechanicalDVR is offline   Reply With Quote
Old 07-25-2007, 08:29 AM   #3
RippySkippy's Avatar
Some showers are 2"
Most sinks and tubs are 1-1/2"
Many residential floor drains are 2" I really depends on what you plan on doing with the drain. Past houses have had both...and each worked equally well. If I were to plumb one in from scratch, I'd put in a 3" line.
RippySkippy is offline   Reply With Quote
