Old 02-15-2011, 12:26 PM   #1
Pipe size question for supply side...
Hi all, thanks in advance for any advice you might know/think.
Supply from our well is a one inch pipe. Supply for both hot and cold to the fixtures (kitchen, bath, and laundry) reduces to a 1/2" pipe. Water pressure ranges from 30 to 50 lbs. I'm adding a second bathroom that will have a shower, toilet, and sink.
My question is whether I can supply the new from existing 1/2" pipe or would I be better off T-ing off the one inch supply? Thanks again... Al
Alvis is offline   Reply With Quote
Old 02-15-2011, 03:52 PM   #2
Go off the 1"
michaelcherr is offline   Reply With Quote
Old 02-15-2011, 11:21 PM   #3
Homerepairguy's Avatar
I would T off the one inch with a 3/4" trunk line to the bathroom. Then appropriate sizes to the different fixtures.
Homerepairguy is offline   Reply With Quote
Old 02-15-2011, 11:38 PM   #4
Persona Non Grata
VIPlumber's Avatar
Why not just disconnect the 1/2" supply at the 1/2" x 1" connection and replace with 3/4", then use the same 1/2" runs to each fixture? If you're going already shut-off the water all it takes is a little planning and you'll increase the pressure to those 30 psi fixtures.
Just my $0.02.
VIPlumber is offline   Reply With Quote
Old 02-16-2011, 05:57 PM   #5
I agree VIP, but the 1" for the hot water is buried somewhere in the wall. Without tearing the house down it seems I'll 'have' to tee the 1/2" hot under the house and run it to the new sink and shower, a distance of 18 feet. Hmmm, I wish I did this differently the first time... lol. The cold water will be easy to tee off of however, and that's what I'll do.
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 02:42 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 12:27 PM
Ventalation Pipe Question JordanB Plumbing 2 12-09-2010 01:19 AM
Iron Pipe Load Question wombosi Building & Construction 7 02-10-2009 04:42 PM
grounding to water pipe question eastvantrading Electrical 6 12-20-2006 10:49 AM
