Old 07-22-2010, 09:33 PM   #1
Pipe size needed for outdoor Gas Grill
I am running a copper line for natual gas for an outside grill. The Grill is 65K BTU rated and the lengh of the run from the gas meter to the grill is approxiamtely 60 ft. Will a 5/8" diameter pipe give enough volume of gas for proper operationi?
chausman is offline   Reply With Quote
Old 07-23-2010, 06:54 AM   #2
Licensed Master Plumber
Do you know your inlet pressure?
Length and size of current piping"
can you use copper?
Call a professional before you blow your house up.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 07-23-2010, 09:44 AM   #3
Owner
LateralConcepts's Avatar
Pretty sure you need to use black iron
I agree with NHMaster. Call a plumber that's licensed for gas.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
Old 07-23-2010, 03:49 PM   #4
Super Moderator
Copper is not allowed inside the house in this area---Black pipe only. Check with the code people.
Old 07-23-2010, 10:02 PM   #5
Copper is fine were we live in Indiana. I already have a line that I ran 10 years ago, so I'm not going to blow up my house. My old line is 3/8" and was for a smaller grill. My new grill is 65K BTU so I know I need a larger line. Just hoping someone out there knows about a chart that shows how big the line needs to be based on the length of run and the BTU output needed.
Old 07-23-2010, 10:53 PM   #6
This might help you calculate it:
http://www.propane-generators.com/natural-gas-chart.htm
Old 07-24-2010, 03:41 PM   #7
Here is a great chart I found for calculating the size needed based on the run and BTU output:
http://www.chimneysweeponline.com/hogasflow.htm
I ended up using 5/8" brass and my run was just under 50ft. The grill works great and tested all the joints for leaks with soapy water.
And for all your worried contractors out their, my house is still standing. This is a very easy do it yourself project for most handy homeowners.
If anyone needs some help in the future with a similar project just let me know. Time to put some steaks on grill!!
Old 07-25-2010, 12:35 AM   #8
5/8 brass?
Old 02-11-2011, 09:30 AM   #9
I know this reply is very late to when chat was active but, I was just reading it and wanted to add something just in case anyone in the future is reading it for advice. Copper tubing should not be used for natural gas use. It corrodes from the inside out and causes copper flakes to flow in direction of gas and potentially clog or damage appliance.
TheGasGuy is offline   Reply With Quote
The Following User Says Thank You to TheGasGuy For This Useful Post:
oh'mike (02-11-2011)
Old 02-11-2011, 09:41 AM   #10
old guy contractor
tcleve4911's Avatar
In Maine........ all exterior gas lines must be black iron pipe.
tcleve4911 is offline   Reply With Quote
Old 02-11-2011, 11:41 AM   #11
Moderator
Termite's Avatar
You're wrong in saying it should not be used. Are there better products? Sure! But it isn't necessarily illegal, stupid, or prohibited.
Reference IRC section G2414.5.2, or IFGC 403.5.2 Copper tubing.
Copper and brass tubing shall not be used if the gas contains more than and average of 0.3 grains if hydrogen sulfide per 100 cubic feet of gas.
It can be used if your gas company delivers gas that meets the code requirement. Many cities have prohibited it due to the gas hydrogen sulfide, but unless specifically/locally prohibited it absolutely can be utilized.
For the layman, we're not talking about the same gas pipe you run water in. Fittings must be brazed (not soldered), and so on.
Old 02-11-2011, 01:24 PM   #12
Experienced
Jackofall1's Avatar
No need to change the 3/8" line, a 3/8" line sized for a velocity pressure of .3" wc would carry over 200 CFH, given gas has a BTU content of 1000 BTU's/CF, you have more than enough with 3/8" line.
When sizing a line with a velocity pressure of .3" line losses really don't have to be considered if the line length is less than 100'.
Mark
Old 02-11-2011, 03:12 PM   #13
Moderator
Termite's Avatar
Mark
Not how I'm reading it in the code. I think you might be getting your data from the 2psi chart, not the 1/2psi chart. I assume the OP does not have a 2psi system in their home, as most folks do not. The IFGC chart for a .5"wc (1/2psi) system, which is most common in residential applications, says that 3/8" type K copper tubing is good for 21 cubic feet per hour at a length of 60' from the meter (assume 21,000 btu/h).
To get type K copper to run 65000 btu/h's at 60', a 3/8" pipe isn't even close. It would take a 5/8" pipe, which has a 74,000 btu/h capacity.
The challenge here is that the correct way to size gaslines (per the IRC and the IFGC) is based on the longest length method, not necessarily the length of the individual pipe in question. All pipes in the home are sized based on the longest pipe in the branch or home. We don't have that information.
This is a very old post, so the OP probably still isn't seeking our help.
Old 02-11-2011, 07:00 PM   #14
Experienced
Jackofall1's Avatar
Granted my first numbers were wrong, but here is what I calculate for a 3/8" Type K copper line.
Inlet Pressure - 16" or 8 oz/in2 or .50 psi
Line length - 60'
SG of gas - .6
Line Size 3/8" ID - .305"
Pressure at Device - 6" or 3 oz/in2 or .19 psi
Flow rate - 61 CFH
If the line size is increased to 1/2" or .527" ID
Resulting flow rate 135 CFH with the same pressure as above.
If incoming pressure is less then a 3/8" line will really suffer, but if its more then you could very well achieve the required flow.
I am not advocating to do this, I am just demonstrating that it can be done, the only negative that would come out of that would be less heat at the barbeque, at which point you could increase flow by adjusting the regulator.
Old 02-12-2011, 07:56 AM   #15
Good point from Thekctermite use K copper only not cheap shelve M copper for water usage.
COLDIRON is offline   Reply With Quote
Size of whole house fan needed Doug Crf General Discussion 20 02-26-2011 12:29 AM
Help with Nat. Gas Line for Grill albertgarrido Plumbing 7 06-29-2010 02:57 PM
Pipe size for hose bibb BigJimmy Plumbing 1 03-12-2007 02:53 PM
Size of laminate layout before t-joints are needed wingman Flooring 1 06-22-2006 10:42 PM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 05:42 PM
