Old 03-12-2007, 02:10 PM   #1
Power Gen/RS Engineer
Pipe size for hose bibb
I will be replacing the cold water piping in my basement soon. The existing line is a combination of 1" galvanized and black pipe which I will replace with 1" copper. There is one existing hose bibb and it appears to be fed using 1/2" black pipe. I intend on replacing this branch as well as adding another for a total of two exterior hose bibbs. Can someone recommend a size for these branches? 3/4"?
Thanks,
Jimmy
Think of how dumb the average person is. Now remember that half of all people are dumber than that-George Carlin
BigJimmy is offline   Reply With Quote
Old 03-12-2007, 02:53 PM   #2
While it is possible to find 3/4" hosebibs, most are 1/2". Unless you are going to be using both hosebibs at the same time, I would go with 1/2" lines to them.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
More On This Topic
Anyone living with large, steaming hot radiators in their home will eventually think of replacing them with something smaller and cooler. A simple solution is to replace your radiator with a smaller, less sizable convector. Here are the steps to replace... Read More »
We are doing a kitchen remodel, and we’re installing the sink. We have replaced one of the supply lines, we have the sink in, and the supply line is connected to the outlet valves. Now we’re going to install a dishwasher drain. You put it on... Read More »
Even though a relaxing campfire at the end of a day in the woods is the perfect end to the day, you can spice it up by adding some colorful flames to a campfire. There are various products on the market that do the same thing, but you might be able to... Read More »
At some point, you may need to replace the flashing around the vents in your roof. If you aren't afraid of heights, you can replace the flashing yourself. Make sure you don't fall. Also, wear gloves to protect your hands from the sharp edges of the vent... Read More »
Before you buy a house, it is a good idea to either inspect it yourself or hire a professional to do it for you. If you do not know what to look for, you may end up with repairs and problems you did not expect. Here are some tips on how to inspect... Read More »
reducing pipe size for sink drain bluebee1314 Plumbing 5 12-02-2007 01:53 PM
drain pipe size for kitchen sink, garbage disposal, and dishwasher ? amakarevic Plumbing 5 08-05-2007 01:23 AM
Water Pipe Size for Double Shower froddan Plumbing 12 08-03-2007 09:46 PM
pipe size for tub, floor, and bath sink drains amakarevic Plumbing 2 07-25-2007 08:29 AM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
