Pipe Size - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-14-2013, 06:39 PM   #16
Im thinking right to left. Because they had to shut it from the street. Cant tell neither
ThenorNCo is offline   Reply With Quote
Old 10-14-2013, 06:43 PM   #17
Rewards Points: 582
ok.. thats very odd to see that type of pipe for that purpose...sorry can't be of more help..ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
plummen (10-15-2013)
Old 10-15-2013, 09:22 PM   #18
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
U cant answer the question ignore it. No need to b an...
You didnt give us enough info to base an answer on.
It depends on what size tap/corp you have at the water main.
But in Bens defense Im going to say get a 2" tap on the main then reduce it down to 1" just before it enters the house then put a 3/4" ball valve inside before reducing it down for a 5/8" meter,That should cover just about any situation from the info we've been given to go off of.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
ben's plumbing (10-15-2013)
Old 10-16-2013, 04:02 PM   #19
Rewards Points: 1,678
1 inch pvc.
What size tube spout for 5inch pipe? Arsinek Plumbing 9 08-13-2012 11:31 AM
Propane pipe size anesthes Plumbing 11 01-31-2012 10:48 AM
Hole size in stud for DVW pipe spring3100 Plumbing 3 12-20-2011 02:18 PM
Using sharkbite to fit leak in pipe...pipe hole size question. RyanD Plumbing 4 08-14-2009 07:17 PM
Pipe Size pochi Landscaping & Lawn Care 2 07-04-2009 04:13 PM
