Pipe Size - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-14-2013, 04:24 PM   #1
pipe size
What is the pvc size before the house meter?
ThenorNCo is offline   Reply With Quote
Old 10-14-2013, 04:26 PM   #2
Rewards Points: 582
I give up ben sr
Old 10-14-2013, 04:33 PM   #3
bbo
Originally Posted by ben's plumbing View Post
I give up ben sr
and you call yourself a plumber.
It's right sized of course.
Unless its not.
then its wrong sized.
bbo is offline   Reply With Quote
The Following User Says Thank You to bbo For This Useful Post:
plummen (10-15-2013)
Old 10-14-2013, 04:48 PM   #4
Wat r u talkin bout
Old 10-14-2013, 04:50 PM   #5
Rewards Points: 3,130
Originally Posted by ThenorNCo View Post
Wat r u talkin bout
What they're talking about is there's no way to answer your question. The pipe could be one of several sizes.
Old 10-14-2013, 04:53 PM   #6
Rewards Points: 14,010
PVC should not be used in a pressurized line, it's made for drains.
No one here can see what size it.
Measure it.
http://www.harvel.com/piping-systems...-80/dimensions
Old 10-14-2013, 04:54 PM   #7
bbo
I think that's what we are saying.
what service are you talking about? you may need to measure outside diameter to determine. or call the utility. I'm guessing its water, but your community may be like mine with many varied water pipe sizes. There are different monthly charges for different pipe sizes so here, it may be standard for 3/4 meter ( thats mine ) but it could be different.
Just curious, what are you needing pipe size for?
Old 10-14-2013, 04:58 PM   #8
Im helping a friend 300 miles away. All i have is a pic.
Old 10-14-2013, 04:59 PM   #9
I give up ben sr
U cant answer the question ignore it. No need to b an...
Old 10-14-2013, 05:03 PM   #10
Looks like 3/4.
Old 10-14-2013, 05:15 PM   #11
Rewards Points: 582
did not mean to offend you just alittle humor to get things started....1st pvc is not used on water lines...2 nd it could be standard supply copper 3/4"..3 rd it could be standard low pressure supply which would increase to 1" copper ..4th it could be different types of plastic allowed by different areas....you see what i mean it hard to say so don't be so touchy we want to help....show us a picture ...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 10-14-2013, 05:22 PM   #12
Old 10-14-2013, 05:26 PM   #13
Rewards Points: 582
its size is 3/4" .....have to say it looks like pvc ...but that would be not right for supply from city..ben sr
ThenorNCo (10-14-2013)
Old 10-14-2013, 05:32 PM   #14
MarginallyQualified
Rewards Points: 2,464
Duct Tape.
That's always a good sign
The Following User Says Thank You to TarheelTerp For This Useful Post:
ben's plumbing (10-14-2013)
Old 10-14-2013, 05:36 PM   #15
Rewards Points: 582
can we see the whole meter spread so we can determine which way the service is flowing.. left to right ..or right to left...ben sr
What size tube spout for 5inch pipe? Arsinek Plumbing 9 08-13-2012 10:31 AM
Propane pipe size anesthes Plumbing 11 01-31-2012 09:48 AM
Hole size in stud for DVW pipe spring3100 Plumbing 3 12-20-2011 01:18 PM
Using sharkbite to fit leak in pipe...pipe hole size question. RyanD Plumbing 4 08-14-2009 06:17 PM
Pipe Size pochi Landscaping & Lawn Care 2 07-04-2009 03:13 PM
