Pipe Size - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-09-2012, 11:06 AM   #1
Pipe size
I have a water line outside connected to my hoseand every year when I turn my water on the pipe is split. I winterize, drain the line and open the nozzles, is the 1/2 too small
patstevens68 is offline   Reply With Quote
Old 08-09-2012, 12:34 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 334
Ayuh,.... It don't matter what size ya use,...
It's gotta be blown out, nearly Dry, or any water left sits in a sag, 'n freezes, splittin' the pipe...
Old 08-09-2012, 02:17 PM   #3
Rewards Points: 12,802
Is this an above ground line?
Do you have it connected to water hydrant?
Post a picture.
Old 08-09-2012, 02:52 PM   #4
joed's Avatar
Rewards Points: 11,534
It splits because there is water in not because it is too small. You might drain it but if the shut off has tiny leak it will drip and fill it again.
Propane pipe size anesthes Plumbing 11 01-31-2012 10:48 AM
Hole size in stud for DVW pipe spring3100 Plumbing 3 12-20-2011 02:18 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 01:10 PM
Using sharkbite to fit leak in pipe...pipe hole size question. RyanD Plumbing 4 08-14-2009 07:17 PM
Pipe Size pochi Landscaping & Lawn Care 2 07-04-2009 04:13 PM
