Old 05-30-2010, 03:50 PM   #1
Pipe replacement under slab floor
I have a 1960's ranch w/ basement. The 1-1/2" drain pipe under basement slab needs to be replaced. It is about 24 feet long. What is best solution ? Can it be done ?
sawsco is offline   Reply With Quote
Old 05-30-2010, 07:02 PM   #2
GC/Master Plumber/Mech
If you have had it rodded and there is no change then yes it may need to be replaced
There are a couple ways
1. Demo hammed busting out the concrete
2. Concrete saw and demo hammer. This usually give me the best results as it gives sqare edges when pouring back the concrete.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
The Following User Says Thank You to Plumber101 For This Useful Post:
sawsco (06-04-2010)
Old 05-31-2010, 08:08 PM   #3
yes, you'll have to cut/smash the concrete to do it though. Also, why does it need to be replaced?
Charlie.Liu is offline   Reply With Quote
The Following User Says Thank You to Charlie.Liu For This Useful Post:
sawsco (06-04-2010)
Old 06-04-2010, 01:03 PM   #4
Will be adding more load to the pipe w/ excessive volume (for the pipe size) Thanx !
Old 06-04-2010, 04:31 PM   #5
just a thought, don't know what your circumstance is but if there is nothing wrong with underslab pipe other than size, do you have to tie into it or can you run new pipe for added load over head or around to get from point a to point b?
just a guy is offline   Reply With Quote
Old 06-05-2010, 12:50 PM   #6
Yeah, I may have to go over-head. Thanks for the thought.
How to cover a hole in a floor slab tomseeley Flooring 2 11-16-2009 01:14 PM
Hardwood floor questions (56K) ukrainetz Flooring 1 08-02-2009 02:08 PM
covering a drain pipe in a cement floor sv9779 Plumbing 5 04-10-2009 10:35 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
Question Pipe broke in/under slab Evnldr Plumbing 6 06-25-2008 08:28 AM
