Pipe Removal In Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-26-2014, 03:18 PM   #1
Pipe removal in basement
Hi,
I have a pipe meant for the shower and a pipe meant for the toilet that are sticking out of the wall and concrete floor respectively in my basement. I need to drywall the open section in the wall and add laminate panels to the floor. Because they are sticking out, I have to remove some part of the pipes. As they will be covered, I want to be confident there won't be any water leaking out. Any advice?
Here is a picture of what I mean (ignore PEX pipes). The shower pipe is the black one on the left hand side and the toilet pipe is at the bottom right.
Thanks a lot!
Phil
phils14 is offline   Reply With Quote
Old 03-26-2014, 03:23 PM   #2
DIY staff
Rewards Points: 7,174
Are you planning to floor and wall over the plumbing rough in ---no new bathroom in the plans???
Old 03-26-2014, 03:30 PM   #3
Yes exactly!
Old 03-26-2014, 03:47 PM   #4
DIY staff
I think you can simply cut the sink drain just below the T and cap it---does the pipe above the T have an AAV ?(air admittance valve)---If that pipe continues upward---(no AAV)--replace the T with a section of pipe---in case that is a wet vent---
The water line for the toilet?---open the drywall--cut off the stub out and cap that inside the wall.
Old 03-26-2014, 06:54 PM   #5
Rewards Points: 1,952
Make sure you cut and remove that mechanical vent. Do not leave it buried in wall it will leak sewer gas eventually.
Old 03-26-2014, 07:14 PM   #6
Yes it has AAV ! so just cap it under the T ?
And no it is not the water line pipe, its the drainage pipe of the toilet that i have an issue (bottom right on picture on the ground). The cap is above the ground surface and I wanted to make it as flush to the ground surface as possible for my panels.. Any ideas??
Thanks a lot!
Old 03-26-2014, 08:56 PM   #7
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
Phil, is the toilet drain accessible from below the floor? if so cut and cap below floor level.
Just an off the wall question though. Was the electrical outlet and phone jack already there when you started this project?
Gregg M.
gmaint is offline   Reply With Quote
Tags
basement , bathroom , pipe , wall , water leak
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 01:56 AM
tapping into basement tub drain muellertr Plumbing 11 02-07-2013 01:38 PM
i'm about to cover up this pvc pipe in my basement danxp Concrete, Stone & Masonry 5 12-10-2012 07:05 PM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 01:29 PM
