Pipe Noises - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-02-2012, 12:50 PM   #1
pipe noises
What would cause pipes to sound like they are going to burst thru the floor when the hot water is turned on at any faucet? Then after an hour of the water being off you can hear the floors creeking.
KenWSmith is offline   Reply With Quote
Old 11-02-2012, 01:02 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 2,120
Can you give us a bit more information?
How long have you lived there?
1 or 2 story?
Has any work been done recently?
Can you describe the sound a bit better?
ddawg16 is online now   Reply With Quote
Old 11-02-2012, 01:31 PM   #3
I have lived here for 3 yrs.House is a ranch with a full basement,new construction in 2009.Sounds like bagnging going thru the floor all the way to the faucet.
What kind of ABS or PVC pipe cutter do you prefer Pirulo Plumbing 10 09-18-2012 12:12 AM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 09:23 AM
Whatís the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 01:42 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
