Old 12-03-2007, 03:54 PM   #1
Pipe noise upstairs bathroom when running only warm water
I have a 6 year old 2 story house on a slab. The bathroom on the 2nd floor has one of those single handle tub and shower fixture. When I turn the single lever all the way to hot or all the way to cold, there is no banging noise. When I put the lever to the middle to mix the hot and cold water, the pipe starts banging.
This weekend I cut the drywall behind the bathtub to see what's going on, and noticed the cold water pipe seems to be banging and vibrating only when I put the lever exactly in the middle position. Again, no problem in only hot or only cold position.
Also the spout diverter and the pull pin has competely fallen out. I tried putting it back in but it just falls out when you pull on the pin.
This faucet is the only one in the entire house (including toilets) that is making noise.
Since the banging only happens in the middle warm position, could it be the faucet itself that is causing this. I want to see what you guys think before I spend money replacing the faucet or doing something unnecessary.
dial2fast is offline   Reply With Quote
Old 12-04-2007, 12:39 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Replace the tub spout-with-diverter.
It will either screw onto a pipe from the wall or slide onto a pipe from the wall and be held by a set screw in a slot up underneath.
Clamp the pipes in the wall or tap a beveled shim in next to pipe passing through any wood frame holes to help alleviate the hammer.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
More On This Topic
Hi I am Mark Williams and on behalf of Expert Village and the producer of this series you can visit our website at www.williamspictures.net. Your common lav faucet consist of four main parts: you have your pop up down in the sink basin, you have hot and... Read More »
We did here in our houses. We have the good insulation but it was not good enough for me. So when we got all these packages from the company's with all these Styrofoam chips in there, we used these chips and put them on top of the ceiling and add to the... Read More »
Hi! I'm Arnesia Frances from Bell Nursery in Burtonville, MD for Expert Village. We are going to help you get your garden ready for the Winter. This is probably going to be the last time that I water out here because it is really starting to get cold and... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will show you step 1 for installing a ball valve. I am going to be installing a ball valve on this pipe. This pipe is a hot water pipe, and I know that because when I trace it back, it... Read More »
Before you buy a house, it is a good idea to either inspect it yourself or hire a professional to do it for you. If you do not know what to look for, you may end up with repairs and problems you did not expect. Here are some tips on how to inspect... Read More »
Low hot water pressure crebive Plumbing 26 01-10-2010 12:54 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
Strange noise associated with hot water - New Question johnny Plumbing 2 08-26-2007 09:40 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
