Pipe Just Started Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2009, 08:58 PM   #1
gruntman's Avatar
Rewards Points: 79
Pipe just started leaking
I was painting my basement office this afternoon and noticed a pipe that had been previously painted that had bubbles forming under the paint on the bottom of the pipe. I was going to paint over the pipe but before I did I knicked it with a blade to shave off the old paint. A chunk of paint and rust came off and the pipe started leaking. I discovered that this is the pipe leading from my sink/dishwasher to the main. It is about 15 feet long. I have a couple of plumbers coming over on Monday to check it out. Do you repair something like this or replace? Thanks
gruntman is offline   Reply With Quote
Old 08-15-2009, 09:53 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Replace the old cast with PVC
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-15-2009, 10:36 PM   #3
gruntman's Avatar
Rewards Points: 79
What should something like that cost?
Old 08-15-2009, 10:46 PM   #4
Rewards Points: 560
That all depends on how much will need to removed and replace and your areas cost of living.
Old 08-20-2009, 08:53 PM   #5
gruntman's Avatar
Rewards Points: 79
I received quotes ranging from 500 to 1,500 dollars. Wrapped the pipe in duct tape and it stopped leaking. Bought me time to find a better deal.
Old 08-20-2009, 10:11 PM   #6
how much of the pipe is he replacing for the $500?
plumber Jim is offline   Reply With Quote
Old 08-20-2009, 10:17 PM   #7
Registered User
Termite's Avatar
Since this is a DIY site, please refrain from discussions regarding the costs plumbers should charge to do work.
Old 08-20-2009, 10:37 PM   #8
Rewards Points: 1,088
If that pipe is completely accessible, you can do it yourself.
A 10 ft. section of 2" pvc pipe can't cost more than $10.
handy man88 is offline   Reply With Quote
Leaking kitchen sink drain pipe zasior Plumbing 10 01-11-2009 07:22 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
Leaking waste pipe Ailish Plumbing 2 08-06-2008 09:19 AM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
Leaking waste pipe guvlin444 Plumbing 5 09-30-2006 01:36 PM
