#1 |
Pipe identification
this is a picture of a drain that is in my basement floor, near my furnace. i would like to drain the condensate fluid from the furnace into this drain. the condensate is slightly acidic, and i have heard that if the pipe is made of galvanized steel, it won't stand a chance. if it is cast iron, it will be OK. is this true?
http://imgur.com/9SIGH i know its hard to tell as the pipe in the picture is 72 years old and there's a bunch of crud on it! but is there any way to tell if it is galvanized or cast? it is 2 inches in diameter and there is a slightly rusty hue along the inside rim, which leads me to think it is cast iron, but i wanted to get a second opinion. all the other drains in the house are cast iron. any help is appreciated... thanks lmorsino |
#2 |
Pipe identification
Looks like cast to me.
#3 |
call me E
Pipe identification
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
#4 |
Pipe identification
That is a picture of an old bell trap. It is made of cast iron and set in concrete. Directly under the trap it transitions to 3 or 4 in. clay pipe.
you will be fine to drain into it. |
#5 |
Pipe identification
Thanks everyone, for your opinions!
#6 | |
Pipe identificationQuote:
For future reference, in a pinch you can tell the difference by lightly touching with a grinder. Cast iron will have very few sparks and they will be red. Steel will have many sparks and will be yellow. |
| The Following User Says Thank You to Fairview For This Useful Post: | ben's plumbing (10-19-2012) |
| Display Modes | |
| Working with B-Vent pipe for WH vent | BobN | HVAC | 16 | 01-26-2012 12:58 AM |
| Best way to join Poly pipe, for a water pipe repair. | carl1864 | Plumbing | 9 | 08-21-2011 03:17 PM |
| Qs about the 1/2"dia brass pipe we bought | smoochas | Plumbing | 10 | 02-21-2011 10:23 AM |
| What’s the best way to remove pipe from T | Jaylyn | Plumbing | 2 | 02-03-2011 02:05 AM |
