Old 10-27-2012, 05:58 PM   #1
Pipe hook up for new drain
Hi again,
I'm hooking up a new drain, and after the help I had earlier was hoping for some more
The sink is being installed in a room in my basement. 1.5" abs pipe will run from the sink through the walls to the existing main waste trunk and vent.
The vent currently has the slop sink in the laundry room hooked up to it, and I am hoping to do the same with the sink.
I've included pictures of the existing piping from the slop sink, the vent connection and the options for connecting it that I have come up with. I'd like some advise as to the best and/or correct (code compliant) way of making the connection.
Option "A" looks like it is the "Correct" way, but will require extending the upright from the "U" on the slop sink drain by 2" to accommodate the clean out, which will actually put it above the level of the slop sink vent.
Thoughts?
Note: I'm in Ontario, Canada.
Pipe hook up for new drain-existing-slop-sink-drain.jpg   Pipe hook up for new drain-existing-stack.jpg   Pipe hook up for new drain-connection-options.jpg
dblade is offline   Reply With Quote
Old 10-27-2012, 06:28 PM   #2
Super Moderator
That is a bit confusing---what is the P=trap for? Could you take a picture from farther back?
A is bad--B looks okay or C----crosses should always be avoided unless there is no alternative.
oh'mike is online now   Reply With Quote
replacing washer drain pipe robertkirkland Plumbing 51 08-12-2012 11:21 AM
Replacement of existing drain pipe from Kitchen and dishwasher RogerM Plumbing 1 10-13-2011 02:48 PM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 04:05 PM
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 1 07-12-2009 11:46 PM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 10:36 AM
