#1 |
Pipe fittings and slope
Hi all,
I've read that when installing a toilet drain, the slope should be around 1/4" per foot. What I don't understand is this--when you have a pipe with a slope like this, and then you connect a 90-degree closet bend and a vertical pipe, how do you prevent the vertical pipe from also having a slope? I've attached a drawing in case I'm not explaining well. Thanks! |
#2 |
call me E
The old screw fittings were actually tapped @ 1/4" ft grade. Modern plastic drainage fittings have enough play to allow for minor adjustment. It's not an issue until you drastically exceed 1/4"ft
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
| The Following User Says Thank You to TheEplumber For This Useful Post: | jaydevries (04-10-2012) |
#3 | |
Pipe fittings and slopeQuote:
#4 |
retired elect/hvac/plumb
Depends on how far you are from the stack,most are close enough that you dont need major fall in the pipe.
"facts" have no relevance to this discusion To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Posting from a concrete bunker under a non descript barn |
#5 |
So would ''enough play" mean you could fit the pipe in the red portion of the diagram provided into the cup of the fitting, at an angle so that it runs vertical (again refering to the red pipe in the diagram). Hope this makes sense.
#6 |
Master Plumber
Depends what code your under, IPC 1/8” per foot on a 3” and up sanitary line.
Experience is Knowing what to do next, Skill is knowing how to do it To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 |
call me E
At 1/8" or 1/4" per ft- it will go to vertical
| Display Modes | |
