Pipe Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2010, 09:53 PM   #1
pipe fittings
I have some large pipe on my well system and it has a bunch of nipples and valves. One nipple is bad in the center of the system. How do I replace it. seems like if I loosen one fitting another tightens.
johnfin is offline   Reply With Quote
Old 03-26-2010, 12:28 AM   #2
Always learning...
fetzer85's Avatar
Rewards Points: 262
Could you show us a picture? It's hard to make a suggestion without knowing exactly what you're talking about.
fetzer85 is offline   Reply With Quote
Old 03-26-2010, 06:27 AM   #3
Licensed Master Plumber
That's what unions, slip couplings and the like are for.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 03-26-2010, 07:16 AM   #4
Pro Hack.
you'll have to follow the line untill you get to either a union (it will resemble a big nut with a pipe threaded into each end) or a flanged joint.. (you must replace the gasket if you take the joint apart, Id suggest with a full face gasket as its easier to re-install) or you come to the end or beginning, my guess is its going to be closer to the end of the run.
good luck!
zacker is offline   Reply With Quote
Old 03-26-2010, 10:56 AM   #5
Household Handyman
Rewards Points: 1,408
Depending on the length of the bad nipple: You could cut right through it, remove the two pieces, use two shorter nipples and a union for repair. David
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
misfits b/ween copper supply pipe and fittings amakarevic Plumbing 8 06-10-2008 09:39 PM
iron pipe fittings farrington135 Plumbing 1 07-13-2007 09:16 PM
iron pipe fittings Talman48 Plumbing 2 01-10-2007 06:11 AM
