Pipe-fitting Disasemmbly After Solvent Glueing? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-17-2013, 11:04 AM   #1
Rewards Points: 91
pipe-fitting disasemmbly after solvent glueing?
so what is the easiest way to remove a pipe from a fitting that has been glued in. i trying to remove a fitting from a pipe but with little success so i am looking into plan b which is cutting the pipe flush with the fitting and then removing the pipe from the inside of the fitting. i am thinking hand hack sawing the pipe in segments and prying off-out with a sharp chisel or scredriver...... didnt know if any solvents would loosen the bond....
gwilkrrs is offline   Reply With Quote
Old 04-17-2013, 11:40 AM   #2
Are you just funnin gw? LOL
Seriously, I'm just a newbie but I don't think there is any way in the world to do what you want. PVC and CPVC (I think ABS also, not sure) can never be separated after the cement is put in the fitting and the pipe inserted.
My understanding is the pipe and the fitting then become one, a very strong molecular bond as strong as the pipe itself. I think you just have to throw that stuff away and start again.
But I'm just a newbie I'm sure the pros will give you the correct information.
Good luck!
agoodboy is offline   Reply With Quote
Old 04-17-2013, 11:53 AM   #3
Rewards Points: 91
no- not funnin unfortunately. i am hoping that maybe this is possible to a small level of certainty...... the connection needed to be basically fitting to fitting to work and now needs to be removed and corrected and there isnt enough room for a coupling........ heres to wishfull thinking!
Old 04-17-2013, 12:03 PM   #4
gw I'm a newbie as I said. But there are pvc repair couplings. I never used one but maybe they would help.
I think the way they work is that they are telescoping and allow you to cut out a section and replace it without tearing out more of your installation. At least that's how I think they work. Maybe one would help?
Good luck!
http://plumbing.hardwarestore.com/52...couplings.aspx
Old 04-17-2013, 01:22 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 664
Google ram bit
The Following User Says Thank You to TheEplumber For This Useful Post:
jaydevries (04-19-2013)
Old 04-17-2013, 02:06 PM   #6
DIY staff
Rewards Points: 7,174
Originally Posted by TheEplumber View Post
Google ram bit
P.V .C Ram Bit.mp4 - YouTube
Old 04-17-2013, 05:11 PM   #7
Rewards Points: 4,796
agoodboy is correct. "Glue" is a little bit of a misnomer. You are not really gluing or cementing the PVC pieces together, therefore there is no glue or cement to break through or dissolve.
When connecting PVC, you are essentially welding the pieces together. The "glue" is really a solvent that melts or dissolves the PVC. The melted areas of the PVC flow together (at the microscopic level). Over time, the solvent evaporates and you're left with what is essentially a solid piece of PVC.
Imagine melting the ends of 2 candles, shoving them together and holding them until they harden. That's sort of what you've done.
I've never used the Ram Bit but I like the idea. Good luck.
jeffnc is offline   Reply With Quote
Old 04-17-2013, 07:37 PM   #8
Rewards Points: 37
I use the one's by wheelerrex
http://www.wheelerrex.com/wheeler-re...g-page-41.html
TOOL82 is offline   Reply With Quote
The Following User Says Thank You to TOOL82 For This Useful Post:
jagans (04-17-2013)
Old 04-17-2013, 10:03 PM   #9
Roofmaster
Rewards Points: 2,210
Yeah, its a solvent molecular weld with Tetrahydrafuran (THF) The bits that cut out the core look like they will work, but you better have a serious drill like a Hole Hawg or a Milwaukee right angle with the anti torque handles. Those bits will burn up a home and garden drill in a new york minute, and break your wrist in the bargain!
It would be cheaper to redo it if you can.
Old 04-17-2013, 10:58 PM   #10
Master Plumber
Javiles's Avatar
Rewards Points: 996
Google ram bit
I did, a P$#n* site popped up
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 04-18-2013, 08:53 PM   #11
Rewards Points: 280
Disassembly, I do not know! But if you have to cut and remove pipe from fitting. I just had really good luck using a heat gun.
PVC Toilet flange replacement options
I do not know if I got lucky with this or it will work all the time? If you try it please post your results.
JIm
jjrbus is offline   Reply With Quote
Old 04-19-2013, 07:24 PM   #12
Rewards Points: 1,948
You can peel the hub of a joint if your very careful. These young uns did not plumb before Ram bits.
Take a straight hack saw blade and cut the pipe in the hub several places bake sure you do not cut the hub but you must completely penetrate the pipe in the hub.. Then use a flat blade screw driver and a hammer carefully place the blade of the screw driver between the hub and the pipe pound it in and the first cut piece should pop out if cut right. Continue to do the same for the rest.
The Following User Says Thank You to Ghostmaker For This Useful Post:
gwilkrrs (04-19-2013)
Old 04-19-2013, 07:32 PM   #13
Plumber
Rewards Points: 664
I use to do it this way too. But since ABS went cell core (very little PVC used here) It just tears in layers and next to impossible to clean out
So it's ram bits and a cordless drill for me.
i'd buy the other kind as they're better built but i've got the ram bit set already
Old 04-19-2013, 09:02 PM   #14
Rewards Points: 91
exactly how i did it. go slow and be patient. worked great
Old 04-20-2013, 10:43 PM   #15
I would use a ram bit today also less time consuming and time is money as they say. Just inspect plumbing any more I'm actually banned from working in the trade because of conflict of interest issues.
Order of install? floor, drain pan, pipe fitting, washer mcherno Plumbing 1 06-26-2012 08:47 PM
Connecting PVC to Galv Pipe fitting for Drain froddan Plumbing 19 02-28-2010 03:33 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
Cracked PVC fitting in concrete DJupin Plumbing 6 07-29-2008 03:12 PM
Use of coupling fitting on gas pipe Fred Plumbing 3 01-28-2007 06:13 AM
