Pipe Draining - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-11-2012, 08:04 PM   #1
Rewards Points: 109
Pipe draining
I'm not sure what this is or how to prevent it.. It is draining pretty much all day, it is just a drip but still draining all day., what is it and is it supposed to drip / drain?
mchipser is offline   Reply With Quote
Old 06-11-2012, 08:25 PM   #2
MarginallyQualified
Rewards Points: 2,464
It looks like the condensate drain from the AC.
Throw a few shovels full of dirt into the void then set a flat rock on the spot.
Old 06-11-2012, 08:27 PM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
I'll take a swing at it and say it's a overflow safety for washer drain.
JetSwet is offline   Reply With Quote
Old 06-11-2012, 08:29 PM   #4
Gymschu's Avatar
Rewards Points: 846
Someone sure butchered up your brick work putting in that clean out in the upper left of your photo.
Old 06-11-2012, 08:47 PM   #5
Rewards Points: 109
It's not the washer line or AC.. The other side of the wall is the kitchen sink.. I did add dirt to it, but my damn dogs keep digging it back up.. I think cause it stays damp there..
Old 06-11-2012, 08:55 PM   #6
Pro
JetSwet's Avatar
Rewards Points: 502
Do you have a dishwasher?
It's definitely for a drain because it's white PVC pipe.
Old 06-11-2012, 08:58 PM   #7
Rewards Points: 109
Yea.. But the dishwasher drains into the garbage disposal in the sink..
Old 06-11-2012, 09:01 PM   #8
Pro
JetSwet's Avatar
Rewards Points: 502
And your drain plumbing is PVC righ?
Old 06-11-2012, 09:08 PM   #9
Rewards Points: 109
Yup.. But doesn't it go to the sewer?
Old 06-11-2012, 09:17 PM   #10
Pro
JetSwet's Avatar
Rewards Points: 502
Yea it runs down to your main drain but if your plumbing is not next to any other plumbing like bathroom ect, therefore I don't think you will have a vent just for the kitchen so they shoot that out the side for air release as well as clog safety, so it won't back flow up in your sink.
Old 06-11-2012, 09:25 PM   #11
Rewards Points: 109
So this is "normal"? The master bath is on the wall to the right of that drain though..
Old 06-11-2012, 09:29 PM   #12
Pro
JetSwet's Avatar
Rewards Points: 502
You would have to look at the roof to see of there is a vent pipe in that section of the house.
It's possible that they did it this way for what ever reason.
And the the white cap to the left of it in pic would be your clean out for your drain incase the line clogged up.
Old 06-11-2012, 09:34 PM   #13
Rewards Points: 109
So is the draining normal?
Old 06-11-2012, 09:38 PM   #14
Pro
JetSwet's Avatar
Rewards Points: 502
Condensation can make it drip, I would have a plumber check to make shore.
Old 06-11-2012, 10:22 PM   #15
Plumber
TheEplumber's Avatar
Rewards Points: 684
What temperature is the discharge water?
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 12:31 PM
How to protect PVC pipe when soldering near it? Studly Plumbing 8 11-21-2011 10:10 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 04:01 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
