Pipe Dope Vs Teflon Tape - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-27-2012, 05:38 PM   #1
Rewards Points: 338
Pipe Dope vs Teflon Tape
Is their a reason for using pipe dope over teflon tape on water connections? I just had a helluva time cracking loose a couple of threaded on valves that were gooped up with a heavy load of that cheap white sticky pipe dope.
Why do plumbers use that stuff? Seriously, is it just because it is cheap and easy? I know teflon tape takes a little more time, but sure comes in handy 10 years later when you need to remove it.
NitroNate is offline   Reply With Quote
Old 06-27-2012, 07:48 PM   #2
Rewards Points: 14,026
I've had far less leaks with teflon dope. When it gets wipe off there no loose strings or a white ring like with tape, there's no way to put it on backwards.
Old 06-27-2012, 10:14 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 834
Why I prefer dope (pipe dope that is)
When I drop a can of pipe dope I simply pick it up and continue on
When I drop a roll of tape i have to chase it across the room and then have my apprentice roll it back up..
When I screw pipe together I don't plan on taking it apart.
The best use I've found for tape is tying it to a electricians trailer ball and watching him drive away at quitting time with a 30' tail
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
plumberinlaw (06-28-2012), plummen (06-28-2012)
Old 06-27-2012, 10:19 PM   #4
I prefer pipe dope, but some swear by tape and others like using both. It really comes down to preference. Not all dopes are the same either. On gas applications, the white and blue stuff turns to concrete and the black stuff is like using JB Weld; horrible stuff, I usually go straight to the 24's when I come across it.
hvac benny is offline   Reply With Quote
Old 06-28-2012, 12:14 AM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Rector seal T plus 2 for me anyway
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 06-28-2012, 10:29 AM   #6
Rewards Points: 338
so, the consensus is that plumbers like the dope. maybe it is just the really nasty cheap white crap used in my house that has the consistency of salt water taffy. i have some rector seal stuff that is yellowish, doesn't seem nearly as bad.
Teflon Tape or Pipe Dope Jupe Blue Plumbing 3 05-21-2011 09:17 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
Pipe dope and teflon tape: if it's holding now, can I trust it? nilloc Plumbing 12 04-30-2011 01:28 PM
First time taping - Tape has air under it theedudenator Drywall & Plaster 16 04-21-2010 11:13 PM
Pipe need to be dry when wrapping teflon tape? thisisbrianly Plumbing 5 09-27-2009 09:29 PM
