Pipe Diameter In Residential Housing - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-22-2011, 04:45 PM   #1
Pipe diameter in residential housing
Are there any standard pipe sizes in residential housing or is the only way to know for sure to cut out a section and measure the hole?
kb01 is offline   Reply With Quote
Old 04-22-2011, 07:57 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 348
Pipes are sized according to the fixtures they serve. The pipe O.D. varies depending on the material such as cast iron, copper, galv. steel, plastic, etc. So if you can't recognize the size, take a piece to someone who knows.
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 01:31 PM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 05:01 PM
Pipe + Wood Spinner Woodee Building & Construction 5 03-02-2010 02:44 AM
running black gas pipe lukeg Plumbing 6 10-25-2009 12:16 AM
Copper pipe type for residential water distribution BigJimmy Plumbing 7 12-31-2007 09:39 AM
