Pipe Connects Laundry Sink To Trap - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-25-2011, 07:05 PM   #1
sweaty
Rewards Points: 276
Pipe Connects Laundry Sink to Trap
I am putting in a new laundry sink and it is slightly lower than my old one.I have a plastic pipe to connect to the trap, but I could not seem to put it in far enough. Do I need to clean out the part that I put it into?
Also, my plastic pipe cutting technique sucks. Any tips? And my teflon tape just ripped right off. I know I wound it in the right direction.
sweaty is offline   Reply With Quote
Old 11-25-2011, 07:14 PM   #2
DIY staff
Rewards Points: 7,174
Slow down and explain this one more time----
These are the parts ---connected to the sink--
tail piece and tail piece washer---
P-trap
coming out of the wall--1 1/2" pipe with a threaded trap connector---
New sinks have the drain further back than older sinks---is the P-trap to long?
Tail pieces usually need cutting---
Teflon tape is not used under the sink as all those parts seal by compression---Mike---
Pictures help of you can't figure out how to describe the situation----
ben's plumbing (11-25-2011)
Installing utility sink in laundry room 71Whaler Plumbing 9 11-24-2011 10:33 AM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
minimum drain pipe for bathroom sink to code Lindy_B Plumbing 0 02-17-2011 09:34 PM
Installing bathroom sink - drains off slightly less than pipe diameter lazzlazz Plumbing 17 05-21-2010 05:12 PM
Leaking kitchen sink drain pipe zasior Plumbing 10 01-11-2009 07:22 PM
