Pipe Condensation - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2012, 06:13 PM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
pipe condensation
My supply line comes into our house into the finished room in the basement, Goes into the meter. Then it goes up vertically and then splits, one goes to an outside spigot, and the other goes to a house water filter and then to the house plumbing.
If noticied lately that then is water dripping from the pipe and water filter, I tightened the filter, and wiped down the pipes. It seems to be related to how much laundry (washing) we are doing. At least that is when I noticied it first, was X-mas, when the kids got a lot of clothes. We did about 15 loads of laundry for two days. Could it be from the constant running of water into the washer, and the room being heated???
I use to have insulated pipe wrap on most of that section, but that got all wet so I took some of the wet part down.
Any suggestions
Barry
Barry J is offline   Reply With Quote
Old 12-31-2012, 06:25 PM   #2
Rewards Points: 13,724
Your bringing in cold water into a warm humided home, there's going to be condensation. Lower the humidy using a humidifyer.
Should have been using foam pipe wrap.
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Removing pipe wrap around copper pipe steve3847 Plumbing 1 12-25-2012 02:46 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
condensation pipe from furnace dberning4770 HVAC 1 06-21-2012 01:34 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 03:47 PM
