Old 12-25-2007, 09:19 AM   #1
Bal
Unhappy
Pipe Chatter
This only happens in one of my bathrooms. When you flush the toilet or turn on the water. (I believe cold mostly) There is a lound banging noise that continues for a few seconds whenever the water starts running. I don't know how to address it.
Bal is offline   Reply With Quote
Old 12-25-2007, 12:27 PM   #2
Pipe Chatter
it is most likley the fill valve in the toilet. turn off the valve to the toilet and then turn the the faucet? if the noise is gone? turn back on the toilet valve ans see it the noise comes back? if so replace the toilet fill valve about 15$ replace the flapper at the same time.
ranman469 is offline   Reply With Quote
Old 12-26-2007, 09:06 AM   #3
Building and plumbing
USP45's Avatar
Pipe Chatter
BAL, what we have here is a "Watter hammer". This is caused when the water is flowing thriugh the pipes at a given speed, then it is stopped so fast that the pipes shake. Purchase a hammer arrestor from your local plumbing store and install it on the COLD water line at the bathroom under the house. Problem solved. I am a VA licensed plumber and we have to install these quite a bit on new construction homes. Espesialy on the washing machine. Hope this helps.
USP45 is offline   Reply With Quote
Old 12-26-2007, 07:59 PM   #4
Master Plumber
Pipe Chatter
USP45.....he said it makes the noise when he turns the water on, not off. Bal.... Hammer arresters are to stop hammering when a valve is closed too quickly. You should check the fill valve on the toilet before doing anything else per ranman's instructions.
jpplumber is offline   Reply With Quote
Old 12-26-2007, 08:36 PM   #5
USP45's Avatar
Pipe Chatter
i am sorry, it IS when the water is turned on, again I am sorry
Old 12-26-2007, 09:50 PM   #6
Pipe Chatter
usp45 well did it work? able to find the source
Sewer pipe under concrete driveway marejw Plumbing 7 12-22-2007 05:19 PM
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 04:08 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
