Pipe From Boiler Confusion.. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2010, 03:49 PM   #1
Pipe from boiler confusion..
Hello everyone; I've been trying to figure out how could I run a new pipe to install a new heater cast iron radiator in my basement. The problem is that I dont understand how to "tap into" the right pipe. I have a pipe with two "T" connectors that goes to my son's room. Could I just put one "T" connector in each line goin to my sons room and run the pipes from there?
I have seen some diagrams and it shows that the radiator/heater is connected from one side to the hot pipe and the other to the return but in my case I see they ran two lines going up from the same pipeline using a "T" flow connector?...could someone please explain a little ?
thanks@!
mamut0o1 is offline   Reply With Quote
Old 01-03-2010, 04:16 PM   #2
Licensed Master Plumber
piping either has to run in series or, If you tap off with tees, one of them must be a monoflow tee
NHMaster is offline   Reply With Quote
Old 01-03-2010, 09:24 PM   #3
Can both be monoflow? what is the difference..... it looks like my setup is monoflow hydronic system;; can I use two "t" connectors from the main pipe just as the other ones?
Old 01-03-2010, 09:35 PM   #4
No, you only need one monoflow tee
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 06:40 PM
Vacuum Pipe Confusion jamiedolan Plumbing 9 09-29-2008 09:32 AM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
