Pipe Banging At Inlet - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-28-2014, 08:41 PM   #1
fastback4's Avatar
Rewards Points: 51
pipe banging at inlet
Just today I hear a 'thump, thump, thump, sound coming from the basement as I turned on the dishwasher in the kitchen. About 1 thump per second. I go to the thumping sound and it's at the 3/4" water inlet from the street. I have a pressure regulator there followed by a whole house inline filter. I bypassed the filter and it continued to thump. I increased the water pressure and it stopped thumping. What gives here?
fastback4 is offline   Reply With Quote
Old 10-28-2014, 08:48 PM   #2
Rewards Points: 582
could have a defective pressure regulator....what is your pressure?
Old 10-28-2014, 08:52 PM   #3
fastback4's Avatar
Rewards Points: 51
I'll check it tomorrow as I didn't think of that. Should I be running at 45-55 psi
Old 10-28-2014, 08:58 PM   #4
Rewards Points: 12,794
There's no need for anymore then that.
Old 10-28-2014, 11:18 PM   #5
Rewards Points: 582
while i can agree with joe..here in my area we average anywhere from 60-75 city water.....40-60 well water...
Old 10-29-2014, 12:06 AM   #6
fastback4's Avatar
Rewards Points: 51
is that before the regulator or after?
Old 10-29-2014, 01:54 PM   #7
Rewards Points: 582
after the regulator ..again because here in my area we have high inlet water pressure...90 to 120
Old 10-29-2014, 02:53 PM   #8
Rewards Points: 1,678
Wonder if your water provider was having issues?
Old 10-29-2014, 03:29 PM   #9
fastback4's Avatar
Rewards Points: 51
[QUOTE=Ghostmaker;1423012]Wonder if your water provider was having issues?[/QUOTE
My water pressure at my kitchen faucet head is 50psi. Our water supplier tells me there is no work being done that would have effected our pressure. I believe I may change my regulator.
Old 10-29-2014, 03:36 PM   #10
Sort of sounding like a pump may have failed. Just rebuild the thing its easy.
Old 10-29-2014, 05:11 PM   #11
fastback4's Avatar
Rewards Points: 51
I didn't know water pressure reg's were rebuild-able
Old 10-29-2014, 05:25 PM   #12
Rewards Points: 142
Yes, they can be rebuilt. Sometimes it's faster and easier to replace it. Up to you.
Please post a picture of it. Thanks.
jmon is offline   Reply With Quote
Old 10-29-2014, 06:09 PM   #13
fastback4's Avatar
Rewards Points: 51
Here it is...
The Following User Says Thank You to fastback4 For This Useful Post:
jmon (10-29-2014)
Old 10-29-2014, 06:19 PM   #14
Rewards Points: 142
Nice. You have unions on both ends. 5 minute job to replace it. If you rebuild it, remember how you took it apart or take pictures. Remember to turn water off first and open a couple faucets. Just a suggestion.
If you can't adjust it properly or turns out to be bad, a rebuild kit is about 35 dollars. New one about 60. Your choice.
The Following User Says Thank You to jmon For This Useful Post:
fastback4 (10-29-2014)
Sewer Back Up/ Pipe Relining Question newbinca Plumbing 9 05-10-2013 01:23 PM
How to Estimate Water Flow Rate in Copper Pipe arskiracer Plumbing 12 04-15-2013 09:50 PM
Deep Pipe Clog - Epic Battle Digi Plumbing 37 02-02-2013 12:48 PM
Whatís the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 02:05 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 12:27 PM
