Pipe At 90deg Elbow Won't Budge!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-25-2012, 02:06 PM   #16
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Get the fitting red hot,not the pipe then spray it down with wd40 and yank on it imediately.
Yeah its gonna smoke/stink ,but it should shock it loose
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-25-2012, 07:21 PM   #17
Master Plumber
Javiles's Avatar
Rewards Points: 990
Never came across one I couldn’t break. Cut that pipe closer to the break point, quoting Alan you grab onto the pipe that's cut and try to leverage against that to make one of the other joints loosen up?” if you over heat the 90 you can actually soften it to the point that you oval it with the pipe wrench when you crank on it ,then you’ll really will have a heck of a time getting it apart.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-25-2012, 07:44 PM   #18
plummen's Avatar
Hes gonna have a pretty tough time over heating that 90 with a propane torch !
Old 02-25-2012, 08:03 PM   #19
Master Plumber
Javiles's Avatar
Rewards Points: 990
Not if you use the extra extra virgin olive oil. Sorry couldn’t resist.
The Following 2 Users Say Thank You to Javiles For This Useful Post:
plummen (02-25-2012), VIPlumber (02-25-2012)
Old 02-25-2012, 08:13 PM   #20
Rewards Points: 582
yes posistion yourself for the most leverage...even put a pipe on the end of your pipe wrench making it bigger...
Old 02-25-2012, 08:31 PM   #21
Rewards Points: 636
here is an idea if not able to break free move to next fitting or cut pipe and re thread with a pipe threader
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 02-25-2012, 08:41 PM   #22
plummen's Avatar
Be carefull with using a cheater pipe on something suspended from a ceiling like that,anybody whos ever had a bunch of hangers fail will know what Im talking about!
The Following User Says Thank You to plummen For This Useful Post:
ben's plumbing (02-25-2012)
Old 02-25-2012, 08:46 PM   #23
Rewards Points: 582
yes good point . Iam sure he will be using a back up wrench...I HOPE...
Old 02-25-2012, 09:07 PM   #24
plummen's Avatar
I remember way back when I was 13-14 me and my dad were trying to bust the lugnuts loose on a big ol 69 dodge 2t tow truck.
We had a 3/4" drive breaker bar and a 10' long piece of conduit with both of of pushing/pulling/jumping on the stupid thing
Come to find out after an hour of fighting with it dodge used left handed threads on the lugs on left side of their trucks back in the day,we spent all that time tightening the stupid things!
Old 02-25-2012, 09:25 PM   #25
Hey everyone. I got it!! I went to Home Depot, got a nice think PCV pipe for only like $3 and it helped give the extra torque to my 10" pipe wrench. Fantastic. Thanks for your help!!!!!!!!
Pharmtoxboy is offline   Reply With Quote
Old 02-25-2012, 09:31 PM   #26
plummen's Avatar
10" pipe wrench? As the great paul harvey would say "and now for the rest of the story"
Old 02-25-2012, 10:52 PM   #27
Plumber
TheEplumber's Avatar
Rewards Points: 452
10" pipe wrench- AKA channellock pliers
Old 02-25-2012, 11:07 PM   #28
Rewards Points: 582
A 10"pipe wrench....wow your kidding right thats at a min 14" oh well
Old 02-25-2012, 11:07 PM   #29
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Sounds like my story, except that the nut snapped off, and I had a black eye for two weeks. (from the cheater bar, not my dad)
Journeyman Plumber
Old 02-26-2012, 12:12 AM   #30
Hey plummen I did the same on a 73 Ford two ton. Heated them with a torch and they were not budging. When we tried the old trick of tighten then loosening and then realized they used left handed threads on the lugs too.
Hardway is offline   Reply With Quote
Tags
budge , galvanized , pipe , remove , steel
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 06:53 AM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 09:14 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 04:47 PM
stuck iron pipe on oil tank vent wrybosome Plumbing 3 01-13-2009 10:43 PM
