Pinhole Leaks In Copper Piping - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-28-2007, 01:42 PM   #16
Custom Cabinet Maker
hmmmmmmmmm I kinda suspect all your copper has RED labeling? NOT blue.
IE "M" copper .
skymaster is offline   Reply With Quote
Old 12-28-2007, 04:40 PM   #17
pinhole leaks
What does labeling do ! Does that have to do with thickness?
27narrow is offline   Reply With Quote
Old 12-28-2007, 06:38 PM   #18
Send a message via AIM to Marlin
Yes, their are three grades
M is the thinnest. It's used for heating and other closed systems which don't have much oxygen in them.
L is a bit thicker. This is used for potable water.
K is the thickest and typically only used under ground.
If the recirculating pump is causing all these problems turn it off. You have to wait a few seconds for your hot water but other than that your problem should be solved. Also you said you used pex to replace some of the copper? Check with the manufacturer of the pex to be sure it's approved for use on re-circulating lines.
Marlin is offline   Reply With Quote
PEX vs. Copper Aglease Plumbing 41 02-16-2010 05:14 AM
brass trap to copper drain? bluebee1314 Plumbing 3 04-02-2007 10:29 PM
Questions about copper tubing... SDeeter19464 Plumbing 3 04-21-2006 08:11 AM
Copper Hot Water Tank - Green Stain grover432 Plumbing 2 11-28-2005 11:05 PM
