Old 12-18-2009, 12:20 PM   #1
sweaty
Pinhole Leak
House- 1977 two-story w/ full basement
There is a pinhole leak in the main water supply pipe about 12 inches above where it comes out of the foundation. It is shooting out of a big, plastic nut in between copper pipe and what looks like a rubber slip coupling. The leak is below the shut-off valve. Fortunately, there is a floor drain. How do I repair this?
sweaty is offline   Reply With Quote
Old 12-18-2009, 02:09 PM   #2
Master General ReEngineer
Bondo's Avatar
Pinhole Leak
Ayuh,.... The water is shut off at the Main, then the valve is replaced....
Or,...
You can do a Hot change-out,... Expect to get WET...
Leave the new valve Open, til it's hooked up solid, you won't get quite so WET that way.....
Been there, Done that.....
Old 12-18-2009, 09:59 PM   #3
firehawkmph's Avatar
Pinhole Leak
Sweaty,
Do you guys down there in Virginnie have shutoffs out in the lawn near the street? Here in Ohio we do, and just about every excavator carries a shutoff tool with them.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 07:06 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 02:26 PM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 07:30 AM
Leak in incoming supply line under slab playstationdork Plumbing 13 08-05-2008 09:18 AM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 02:18 PM
