Old 08-13-2007, 08:20 AM   #1
pin holes in copper water lines
My house was built in 1978. Copper is used through out for all the water lines. The past couple of years pin holes have been appearing in the cold water lines. The hot side never seems to be a problem. I have probably fixed 4-5 holes a year. There are green like spots and patches on the outside of the copper itself. I should mention also that we have well water.
What would cause this? Is it a water problem? Bad Copper? Age?
Eric_ht is offline   Reply With Quote
Old 08-13-2007, 09:59 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Water PH is too low, replace the lines with pex pipe.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Attaching water lines to floor joists handyflyer Plumbing 8 04-30-2007 11:43 AM
new water lines JahDoos Plumbing 11 02-22-2007 10:43 PM
Insulating Hot Water Lines jeepwillies Plumbing 1 11-21-2006 03:41 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Copper Hot Water Tank - Green Stain grover432 Plumbing 2 11-29-2005 12:05 AM
