Pilot Light Will Not Stay On!!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-21-2011, 06:02 PM   #1
Pilot light will not stay on!!!
On my gas water heater i can get the pilot lit and get the burner to fire but when the burner kicks off the pilot goes out BUT if i manually turn the thermostat down to kick the burner off the pilot will stay lit.....what gives?????
graham m. is offline   Reply With Quote
Old 11-21-2011, 08:10 PM   #2
how
Rewards Points: 1,104
The normal way to check this is with a thermocoupler adapter and a d*** meter.
This equipement would show if the draft from the latent heat of the hot water heater is pulling the pilot flame away from the tip of the thermocoupler when the main burners go off. It would also help show if the problem is within a faulty gas valve.
Does the pilot still go out when you let the tank heat up for a while and then manually turn down the temp controls?
how is offline   Reply With Quote
Pilot doesn't stay lit avatar2k HVAC 13 12-08-2015 03:22 PM
Pilot light won't light BarryBe HVAC 3 05-22-2011 11:05 AM
pilot light wont stay lit victordd Appliances 1 03-10-2011 07:37 PM
Bryant 394G Furnace Pilot light problem rcgiii HVAC 0 03-05-2011 12:25 PM
Pilot light does not stay on cprao HVAC 11 02-14-2010 05:38 PM
