Pilot Light On Crown Aruba Boiler - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-28-2009, 09:53 AM   #1
Rewards Points: 252
pilot light on crown aruba boiler
Hi everyone,
A few months ago I moved into a new house that has a crown aruba boiler. The house is about ten years old, the boiler is feeding 4 zones of baseboard heat. The boiler has a pilot light and I would assume that this pilot running for the next six months can't be good for my gas bill. The boiler is 140,000 btu's, and I can actually hear the gas running to the pilot and the 6" flue pipe stays warm even though there is no call for heat. Seems like a lot of wasted heat. Any suggestions for mimimizing the waste of gas? Should I change to an electronic ignition? Should I just shut the gas off to the boiler? Someone mentioned to me that the pilot light is good to keep going because it will rid the boiler of any condensation that builds up over the summer.
Thanks in advance!
mazzonetv is offline   Reply With Quote
Old 05-28-2009, 10:13 AM   #2
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
Pilot light on boiler
POST YOUR QUESTION ON THE FOLLOWING LINK THE BOILER EXPERTS HANG OUT THERE !
http://heatinghelp.com/
LOOK FOR THE WALL FORUM !
CORRECTION THIS LINK
http://forums.invision.net/index.cfm...a9e29&CFApp=2&
JERRYMAC@UTAHWEB.COM
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Pilot light on boiler is on but won't flare up! SingleMom HVAC 1 10-07-2008 04:50 PM
Utica Boiler Pilot light on but will not flame up! MGB150HID HVAC 2 12-10-2007 04:48 PM
