Piece Of Rubber Stuck In Basement Shower Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-11-2011, 06:52 PM   #1
piece of rubber stuck in basement shower drain
how would it be possible to remove a round piece of rubber about 2" in diameter that has fallen down a basement shower drain to the far side of the p-trap? If cable doesn't work, do you think that placing the nozzle end of a shop vac down against the shower drain body would produce enough suction to draw the rubber piece up & out. If not then do you know of some sort of chemical that is both strong enough to dissolve the rubber yet be harmless to the ABS plastic pipe?
shwrprob is offline   Reply With Quote
Old 05-11-2011, 08:10 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 562
Shop vac might work but don't pour in any kind of chemical. You'll do more harm then good
Old 05-12-2011, 06:49 AM   #3
Rewards Points: 1,578
Would this work:
http://s95014253.onlinehome.us/media...ex~grabber.JPG
bob22 is offline   Reply With Quote
Old 05-12-2011, 04:21 PM   #4
Homerepairguy's Avatar
Rewards Points: 998
Is it a ball? If so, maybe duct tape a length of garden hose to a vacuum cleaner hose and the suction might hold the ball enough to pull it out.
HRG
Homerepairguy is offline   Reply With Quote
Old 05-13-2011, 02:23 PM   #5
Long-Time DIYer
Mike Swearingen's Avatar
I think that I would try a toilet auger.
It has a hooked spring on the end of its cable and you can twist it with the auger handle to hook onto things and pull them out.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-13-2011, 02:45 PM   #6
Rewards Points: 150
If its soft this mjght work.
http://www.griotsgarage.com/product/...ick-up+tool.do
josall is offline   Reply With Quote
Attaching basement bathtub drain to main drain herbie08 Plumbing 0 04-10-2011 04:13 PM
Adding a basement floor drain for A/C Condensor SuzieSawzall Plumbing 9 03-28-2011 07:51 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Basement Shower Backup robbdc Plumbing 0 12-15-2009 08:22 AM
Installing stand-up shower in finished basement without existing drain notenoughtime Plumbing 3 05-16-2009 11:59 AM
