-   -   piece of rubber stuck in basement shower drain (http://www.diychatroom.com/f7/piece-rubber-stuck-basement-shower-drain-104192/)
shwrprob 05-11-2011 06:52 PM
how would it be possible to remove a round piece of rubber about 2" in diameter that has fallen down a basement shower drain to the far side of the p-trap? If cable doesn't work, do you think that placing the nozzle end of a shop vac down against the shower drain body would produce enough suction to draw the rubber piece up & out. If not then do you know of some sort of chemical that is both strong enough to dissolve the rubber yet be harmless to the ABS plastic pipe?
TheEplumber 05-11-2011 08:10 PM
199 Attachment(s)
Shop vac might work but don't pour in any kind of chemical. You'll do more harm then good
bob22 05-12-2011 06:49 AM
Would this work:
http://s95014253.onlinehome.us/media...ex~grabber.JPG
http://www.google.com/imgres?imgurl=...%3Disch&itbs=1http://www.diychatroom.com/data:imag...AAAElFTkSuQmCC
Homerepairguy 05-12-2011 04:21 PM
Is it a ball? If so, maybe duct tape a length of garden hose to a vacuum cleaner hose and the suction might hold the ball enough to pull it out.
HRG
Mike Swearingen 05-13-2011 02:23 PM
I think that I would try a toilet auger.
It has a hooked spring on the end of its cable and you can twist it with the auger handle to hook onto things and pull them out.
Good Luck!
Mike
josall 05-13-2011 02:45 PM
If its soft this mjght work.
http://www.griotsgarage.com/product/...ick-up+tool.do
