Piece On Bottom Of Toilet Tank Won't Seal - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-14-2005, 08:53 PM   #1
Piece on bottom of toilet tank won't seal
I just installed a new Fluidmaster Fill Valve. It's working just fine, except that the white nut that you hand-tighten at the bottom of the tank won't seal. I've untightened and retightened at varying degrees of tightness and I can't get it to fit just right to where it won't drip.
Should I just keep trying or is there a simple solution?
Squeeealer is offline   Reply With Quote
Old 07-14-2005, 09:13 PM   #2
If you are talking about the Fluidmaster 400A make sure the black washer on the bottom has the bevel side down to the inside of tank. Sometimes I will apply a little pipe joint compound to the washer. Also, I always tighten them with my pliers beyond hand tightening you need that washer to compress. Don't kill it, but a little at a time until it stops. Good luck
plumguy is offline   Reply With Quote
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
How do I seal the bottom of this fountain (pics) weatheredwood Landscaping & Lawn Care 10 08-31-2007 03:38 PM
Two piece toilet leak Tmb9862 Plumbing 5 05-28-2007 03:24 PM
seal a concrete water tank timbo General DIY Discussions 16 01-18-2007 05:08 PM
