Old 09-26-2012, 09:49 AM   #1
pickles = toilet clog
So... We had an incident with someone in the family dumping about half a jar of midget dill pickles down the toilet. (dont ask)
Now the toilet flushes slow. The bowl fills quickly then drains slowly. I have tried the plunger without much luck and I also let it sit overnight. What can I do to bust up a pickle clog?
Total Tool is offline   Reply With Quote
Old 09-26-2012, 09:59 AM   #2
Doing it myself
Alan's Avatar
http://cdn.stripersonline.com/e/e6/e...set-auger.jpeg
Journeyman Plumber
Alan is online now   Reply With Quote
The Following User Says Thank You to Alan For This Useful Post:
Total Tool (09-26-2012)
Old 09-26-2012, 05:09 PM   #3
biggles's Avatar
if you can get a garden hose in there....wrap an old towel around the end of it push it down into the toilet keep it tight and let it rip.... they will break down even some hot water
biggles is online now   Reply With Quote
The Following User Says Thank You to biggles For This Useful Post:
Old 09-26-2012, 10:50 PM   #4
Tried the garden hose. I couldnt get it to make the 180 turn. I didnt use a towel...? Not really sure what you meant by that.
Is there anything else I can try before I go buy an auger? Do any places rent something like that?
I'm thinking part of the problem is that its not a complete clog. I cant create any pressure with the plunger.
Old 09-26-2012, 11:44 PM   #5
It would be just as cheap to just buy one.
Remove the toilet and tip it on it side and pick them out.
Install a new wax ring.
Old 09-26-2012, 11:45 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Closet auger
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following 2 Users Say Thank You to plummen For This Useful Post:
ben's plumbing (10-02-2012), oh'mike (09-27-2012)
Old 09-27-2012, 06:07 AM   #7
biggles's Avatar
the trick is to wrap the wet towel at the end of the hose so all the water pressure goes down into the line not fill the toilet...not looking to snake the hose just pressurize the bowl trap...thats why the towel is used...
Old 10-01-2012, 11:47 PM   #8
Update: Hose trick failed. I bought a cheap toilet auger for $7 from my local menards and it did the trick in a few minutes.
Kids, dont put pickles down the toilet
The Following 3 Users Say Thank You to Total Tool For This Useful Post:
ben's plumbing (10-02-2012), oh'mike (10-02-2012), plummen (10-02-2012)
Actually need to clog a toilet Dan Robbins Plumbing 11 09-18-2011 02:56 PM
New toilet causing clog Bigguy0 Plumbing 0 02-05-2010 03:32 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Is this a reoccurring clog in the toilet waste line? darsunt Plumbing 2 06-02-2008 12:11 PM
