Picking A New Water Heater..... - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-23-2010, 02:22 PM   #1
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Picking a new water heater.....
Well, my water heater is manufactured in 1969 and I think it's finally starting to consider giving up on me.
It's a 40 gal nat. gas one.
Is there any science to this? It's a small 1.5 bathroom house so i'm not going fancy or tankless - just need something similar.
OK to just grab a 40 gallon one at one of the local big box stores?
CoconutPete is offline   Reply With Quote
Old 02-24-2010, 01:01 AM   #2
Always learning...
fetzer85's Avatar
Rewards Points: 262
Yep, sounds like any natural gas water heater would work for you. If you haven't had any issues with running out of hot water quickly then staying with a 40gal model would make sense, otherwise you could upgrade to a larger 50 or 60gal model. The tradeoff is obviously a higher purchase cost as well as operating cost. Also if your water heater has a tight fit wherever you have it situated, the larger model might not be an option.
All in all not much to it. I replaced my 40gal two years ago, two trips to Lowes and half a Saturday and I was good to go. Good luck!
fetzer85 is offline   Reply With Quote
Old 02-24-2010, 05:53 AM   #3
Rewards Points: 85
I replaced mine about 3 years ago, and totally agree with fetzer about the size of the unit, make sure you check DIA and overall height. Another consideration when picking out a new one with height in reference is will the new exhaust match up correctly. You also might need to check with your local code to verify if you need a update to any of the plumbing for the unit or expansion tank. I know here where I live if someone sees a old tank out by the road, most likely you will see a local inspector showing up at their house to check if it was installed properly because an expansion tank is code here from what I understand.
mferguson0414 is offline   Reply With Quote
Old 02-24-2010, 09:41 AM   #4
Rewards Points: 504
No issues w/ space at all - the old one is hanging out on a big empty space next to the furnace. I should post a pic of it - you guys will get a kick out of it. It's pink and made of copper!
Maybe I'll consider upgrading to a 50gal instead of the 40 since we are thinking about adding a family member in the next 1.5 - 2 yrs.
I will probably call someone to have it installed - I am pretty handy but i HAAAAATE sweating pipe.
Old 02-24-2010, 10:01 AM   #5
concretemasonry's Avatar
Rewards Points: 2,566
Just make sure the P/T release works and is discharged at the right height above the floor. No threads, caps or restrictions allowed on the discharge.
The altitude record for one from the basement through a two story home is over 300' due to improper or obstructed relief. On the "Myth Busters" TV show they got to about 500' through a flimsy roof.
Dick
concretemasonry is offline   Reply With Quote
Old 02-24-2010, 10:03 AM   #6
Rewards Points: 504
I LOOOOVED that episode of Mythbusters!
So P/T .... Pressure / ????? What does the T mean?
So if I understand you correct - I can't attach a hose to the pressure relief pipe and run it to a sink?
Old 02-24-2010, 02:55 PM   #7
How much is the scrap metal guy going to give you for it?? Might pay for the new one.
ferris13 is offline   Reply With Quote
Old 02-25-2010, 03:18 PM   #8
Rewards Points: 504
I'm not sure, but there is no way in hell I am just going to let the guy haul it away haha. I'm going to see if I can get a little $ for it first.
Not sure if I should crack it open or what......
Old 02-25-2010, 06:56 PM   #9
40 gallon plenty big, you will end up spending more on a bigger model whenyou need not. rule of thumb is 5 gallons per fixture. tub,lav,kit,dishwasher,laundry,another lav. don't overkill especially when your heater is heating up 24 hrs a day , no need to pay for a bigger unit when not needed. if you need to save money, they do make flexible hookups to make it easier, which are compression
holman23 is offline   Reply With Quote
Old 02-25-2010, 08:08 PM   #10
might find a bootlegger on craigs list for nice still. you probably need a plumber to make gas connection legit even if its an easy hookup, worth checking
The older I get the better I was
Old 02-26-2010, 12:27 AM   #11
Always learning...
fetzer85's Avatar
Rewards Points: 262
I understand your logic but this is not the only thing to consider. If you have 5 or 6 people living in a house and you all bathe in the morning, I seriously doubt a 40gal will cut it unless you've got a very restrictive shower head and you take speed showers.
Old 02-26-2010, 09:24 AM   #12
I went with 50g as I like long hot showers quite often
We have 3 people now in our family plus MIL is here 1-2 days a week
Old 02-27-2010, 02:45 AM   #13
Rewards Points: 150
I would go electric or power vent
rudolph58 is offline   Reply With Quote
Old 02-27-2010, 12:23 PM   #14
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Check pricing on a bigger model anyway. These guys are all saying more expensive for bigger, but around here, we pay more for a 40 gal than a 50 gal.
Journeyman Plumber
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
Electric Water Heater Problem mw2727 Plumbing 4 08-21-2008 02:51 PM
I would like to relocate the flue for my gas water heater Git HVAC 12 04-23-2008 10:37 PM
