Old 03-28-2009, 08:06 PM   #1
Question
(pic) cutting 3" pvc pipe with
hi im trying to make plenty of small 3 inch cuts on a 3" pvc pipe,
im trying to use a saw that i got,
(i tried a hacksaw my hacksaw sucks i need a str8 cut)
will this saw work? any info on doing it? i heard cutting slow might work,
any hazards, is it possible?
thanks for reading.
(pic) cutting 3" pvc pipe with-send.jpg   (pic) cutting 3" pvc pipe with-send4me.jpg
helpmefolks is offline   Reply With Quote
Old 03-28-2009, 08:08 PM   #2
JDC
Plumbing Contractor
JDC's Avatar
I'd guess a compound miter saw with a fine tooth blade would work. I generally use a chop saw or sawzall
JDC is offline   Reply With Quote
Old 03-28-2009, 08:55 PM   #3
so will that saw work?
you got any pics of what a fine blade would look like?
could i use that saw the way it is just go slow then fast?
Old 03-28-2009, 10:41 PM   #4
A "fine blade" has more teeth...smaller teeth.
If you don't want to go with the expense, you could always buy a miter box.
handy man88 is offline   Reply With Quote
Old 03-28-2009, 10:43 PM   #5
HVAC / Plumbing
that blade will work... You will get a smoother cut with a blade thas has more teeth
kenmac is offline   Reply With Quote
Old 03-29-2009, 02:37 AM   #6
i need a very str8 cut i hope this does the job,
thanks for replys folks,
i was thinking i could put it on 2 horse's with a long pz of wood setup shop there
dont really got a long table, wishin i did right about now im sorta a broke ass right now so..
ya..
hehe..
Old 03-29-2009, 11:20 AM   #7
Be extremely careful when cutting PVC with your saw. Make sure you have a "death grip" on the pipe in case it hangs up. Also, wear long sleeves and safety glasses, although I recommend a full face shield. The cuttings flying from the pipe will really hurt on bare skin. Start the cut slow if you are using a blade with fewer teeth to avoid hanging up and throwing the pipe across the area.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 03-29-2009, 09:22 PM   #8
Question
Originally Posted by majakdragon View Post
Make sure you have a "death grip" on the pipe in case it hangs up..
so your saying it might pop up?
thanks for the info guys im taking any info i can get dont wanna hurt myself hehe..
i was told i should stop at 1 foot incase it explodes? so says the hardware store guy?..true false?
Old 03-30-2009, 07:34 PM   #9
When a moving cutting blade hits a round object (PVC pipe) it has a tendency to try to spin the pipe. If you are not holding it tight, it will spin off the blade and the saw table.
Old 03-30-2009, 11:19 PM   #10
Whatever you do, don't try to cut any PVC elbows with a miter saw. Your fingers will thank you for allowing them to still be attached as will your eyes, face, arms, etc from not getting hit by 200 mph flying shattered plastic.
Go slow and be careful and don't cut too short of a pipe. Definitely don't go shorter than 1 foot.
Crosscut saws work well for these cuts. I've also discovered that the manual miter hand saws work very well at cutting PVC.
Also, that saw really needs a guard. I would have lost all the fingers on my left hand when I accidentally had a scrap of wood get jammed against the trigger of mine while moving it out of my way. I unplugged it 10 minutes earlier but didn't realize my brother plugged it back in to cut some trim a few minutes prior. The guard saved my hand.
KHouse75 is offline   Reply With Quote
Old 03-30-2009, 11:28 PM   #11
Why do you need a "straighter" cut than what the pros accept with a sawzall or chop saw?
I used a compound miter saw for 1" and 2" pipe just for the quickness, I dunno it shot a lot of shards out, threw the pipe around, seemed more dangerous than it was worth. sawzall it is for me.
johnnyboy is offline   Reply With Quote
Old 03-31-2009, 01:16 AM   #12
I use a battery 18v cordless Dewalt trim saw and turn the pipe round and round,,,cuts pretty darn straight.
4just1don is offline   Reply With Quote
Old 03-31-2009, 11:51 AM   #13
Rivethead is offline   Reply With Quote
Old 03-31-2009, 06:10 PM   #14
Safe, Most of the Time!!
brokenknee's Avatar
thanks for reading.
Is this for a plumbing project or something else? Nice straight cuts are not necessary for plumbing.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
cutting clay tile pipe johnnyboy Plumbing 5 02-17-2009 07:37 PM
Cutting concrete to hide an a/c drain pipe? CooperChloe Building & Construction 3 02-04-2009 09:28 PM
Cutting Iron Drain Pipe jonathan03 Plumbing 12 01-31-2009 10:33 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
Cutting off 3" of laminate counter top in place 4just1don Building & Construction 3 09-27-2008 10:33 PM
