Old 10-25-2009, 04:15 PM   #1
Default Phosphate Crystals for water treatment?
I moved to a home using well water. My water goes through a
string filter and then through a canister containing phosphate
crystals.
The previous owner said when he changes the string filter every 3
months, he refills the second cannister with phosphate crystals. He
said the phosphate was to reduce corrosion in the copper pipes and prevent staining.
The phosphate crystals are in a container from Kenmore, but I don't think they still sell them. When I search for Phosphate Crystals, I see there are some filters sold that include the crystals, but I do not see a supplier of loose crystals.
Does anyone know a source for the phosphate crystals and the pros and cons of using them?
PaulF1
PaulF1 is offline   Reply With Quote
More On This Topic
If you have ever bought engine coolant, you know that there are many brand choices on the shelves. Although mixing brands generally doesn't create problems, you may want to consider a few factors before deciding what type of coolant to buy. Read on to... Read More »
Over here we have pump parts to replace a lot of different things that can go wrong with your pump that is really simple to replace and most stores have those. Here we have skimmer baskets and these are most of your maintenance supplies; your skimmer net... Read More »
Part 2 - Learn how to string a fender stratocaster electric guitar in this diy guitar setup video. Read More »
Learn how to remove guitar strings to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
Hi, my name is Ella Seltzer for Expert Village. Now we are going to start putting chaton crystal chatons onto the necklace. The reason I left this stage for last is because the glue that I like to use does not dry instantly. So you have to do the gluing... Read More »
Question About French Door Treatment? foster01 General Discussion 3 02-27-2009 04:01 AM
Termite Treatment Chemicals TBear Pest Control 6 10-05-2008 07:35 PM
Good water treatment solution for 10 grain hardness. Philip_Soldat Plumbing 1 09-07-2008 11:12 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
